[GeoNode-users] GEONODE UPDATELAYERS COMMAND
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Sun Jan 5 12:20:30 PST 2020
Hi Benard,
> The issue is that when i try to download the layer from geonode, the download link is reading from localhost:8000 domain instead of my custom domain.
you could try to use this management command to update the download links:
http://docs.geonode.org/en/2.10.x/admin/mgmt_commands/#management-command-set-all-layers-metadata <http://docs.geonode.org/en/2.10.x/admin/mgmt_commands/#management-command-set-all-layers-metadata>
Also make sure to check your geoserver urls for example Proxy Base URL settings.
Cheers,
Toni
CSGIS
Gottschedstraße 12
04109 Leipzig
Telefon 0341. 39 37 3397
Web https://csgis.de
> 1. GEONODE UPDATELAYERS COMMAND (Benard Rodgers Onyango)
> Von: Benard Rodgers Onyango <benardonyango16 at gmail.com>
> Betreff: [GeoNode-users] GEONODE UPDATELAYERS COMMAND
> Datum: 5. Januar 2020 um 20:02:50 MEZ
> An: geonode-users at lists.osgeo.org
> I kindly need help concerning an issue i am facing in geonode.
> I have published a layer in geoserver and now i want to run the command "python manage.py updatelayers -w geonode" to bring the layer into geonode. I have done that and it is successful. The issue is that when i try to download the layer from geonode, the download link is reading from localhost:8000 domain instead of my custom domain.
> But when i upload the same layer through geonode GUI, the download url reads from the custom domain and not localhost.
> How can i solve this problem? I edited local_settings.py and changed localhost to my custom domain. The GeoServer proxy base url is also pointing to my i.p
> Regards,
> Benard Onyango - GIS/RS Assistant
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200105/966e73e3/attachment.html>
More information about the geonode-users
