[GeoNode-users] FW: Geoserver problem deploying spcgeonode with docker over https behind reverse proxy
Francesco Bartoli xbartolone at gmail.com
Mon Jan 6 03:18:02 PST 2020
Hi Silvia,
thanks for reporting. Can you file an issue on GitHub?
Thanks,
Francesco
Il 13 dic 2019, 15:05 +0100, Silvia Salsone <salsone at planetek.it>, ha scritto:
> Hi Francesco, hi all,
> We’ve just found these pages explaining and solving our issue:
> https://osgeo-org.atlassian.net/browse/GEOS-9353?inbox=true&=
> https://docs.geoserver.org/stable/en/user/security/webadmin/csrf.html
> It wasn’t easy to find the right configuration. It would be great to add it to the main documentation, since I believe it must be a common issue.
> Thanks for you support,
> Silvia
> From: Francesco Bartoli [mailto:xbartolone at gmail.com]
> Sent: venerdì 13 dicembre 2019 12:28
> To: geonode-users at lists.osgeo.org; Silvia Salsone <salsone at planetek.it>
> Subject: Re: [GeoNode-users] FW: Geoserver problem deploying spcgeonode with docker over https behind reverse proxy
> Hi Silvia,
> any chance to have the output from the log of the geoserver container? It would help
> Thanks,
> Francesco
> Il 12 dic 2019, 13:04 +0100, Silvia Salsone <salsone at planetek.it>, ha scritto:
> > Hi all,
> > I’ve deployed an spcgeonode with docker, with the following settings:
> > HTTPS_HOST=my_host
> > HTTPS_PORT=443
> > specified in the .env file, as required.
> > I managed to correctly link Geonode to Geoserver using https calls, getting access to it using the Geonode login button (the single sign-on feature).
> > But the issue seems to be inside the Geoserver application, where I get the following error when I click on “Submit” or “Cancel” inside any Geoserver page (i.e. in Global Settings page as in the image below).
> > <image001.jpg>
> > Thus, it seems local Geoserver calls fail!
> > Does anyone have an idea of why I get this error? Can it be I miss anything on Geoserver setting files? Or is it a proxy issue?
> > Thank you in advance for any helpful suggestion.
> > Best wishes,
> > Teresa
> > Teresa Fazio
> > Technical Specialist
> > Government & Security SBU
> > Planetek Italia S.r.l.
> > Via Massaua, 12
> > I-70132 Bari BA - Italy
> > Tel. +39 080 9644200
> > fazio at planetek.it
> > http://www.planetek.it
> > geonode-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200106/9a14555a/attachment-0001.html>
More information about the geonode-users mailing list
