[GeoNode-users] uwsgi service won't start
1520 gis juliermeopensourcedeveloper at gmail.com
Fri Jan 24 08:27:01 PST 2020
Hi developers,
I am following the guide in here
<http://docs.geonode.org/en/2.10.x/install/core/index.html>.
After creating the file /etc/uwsgi/apps-available/geonode.ini
and the symbolic link sudo ln -s /etc/uwsgi/apps-available/geonode.ini
/etc/uwsgi/apps-enabled/geonode.ini
uwsgi service won't start. Any help on that will be very appreciated it.
Find the logs bellow on an Ubuntu18.04LTS machine.
Fri Jan 24 13:12:48 2020 - *** Starting uWSGI 2.0.15-debian (64bit) on [Fri
Jan 24 13:12:48 2020] ***
Fri Jan 24 13:12:48 2020 - compiled with version: 7.3.0 on 28 September
2018 15:41:15
Fri Jan 24 13:12:48 2020 - os: Linux-5.3.0-26-generic #28~18.04.1-Ubuntu
SMP Wed Dec 18 16:40:14 UTC 2019
Fri Jan 24 13:12:48 2020 - nodename: 172-21-14-45
Fri Jan 24 13:12:48 2020 - machine: x86_64
Fri Jan 24 13:12:48 2020 - clock source: unix
Fri Jan 24 13:12:48 2020 - pcre jit disabled
Fri Jan 24 13:12:48 2020 - detected number of CPU cores: 1
Fri Jan 24 13:12:48 2020 - current working directory: /
Fri Jan 24 13:12:48 2020 - writing pidfile to /run/uwsgi/app/geonode/pid
Fri Jan 24 13:12:48 2020 - detected binary path: /usr/bin/uwsgi-core
Fri Jan 24 13:12:48 2020 - dropping root privileges as early as possible
Fri Jan 24 13:12:48 2020 - setgid() to 33
Fri Jan 24 13:12:48 2020 - set additional group 27 (sudo)
Fri Jan 24 13:12:48 2020 - setuid() to 1001
Fri Jan 24 13:12:48 2020 - chdir() to /opt/geonode
Fri Jan 24 13:12:48 2020 - your processes number limit is 23611
Fri Jan 24 13:12:48 2020 - your memory page size is 4096 bytes
Fri Jan 24 13:12:48 2020 -  *** WARNING: you have enabled harakiri without
post buffering. Slow upload could be rejected on post-unbuffered webservers
Fri Jan 24 13:12:48 2020 - detected max file descriptor number: 1024
Fri Jan 24 13:12:48 2020 - lock engine: pthread robust mutexes
Fri Jan 24 13:12:48 2020 - thunder lock: enabled
Fri Jan 24 13:12:48 2020 - uwsgi socket 0 bound to UNIX address
/run/uwsgi/app/geonode/socket fd 3
Fri Jan 24 13:12:48 2020 - uwsgi socket 1 bound to TCP address 0.0.0.0:8000
fd 5
Fri Jan 24 13:12:48 2020 - dropping root privileges after socket binding
Fri Jan 24 13:12:48 2020 - Python version: 2.7.17 (default, Nov  7 2019,
10:07:09)  [GCC 7.4.0]
Fri Jan 24 13:12:48 2020 - Set PythonHome to
/home/geonode/.virtualenvs/geonode
ImportError: No module named site
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200124/37d3c4c3/attachment-0001.html>
More information about the geonode-users mailing list
