[GeoNode-users] GeoNode multi-tenancy using docker environment.
Francesco Bartoli xbartolone at gmail.com
Thu Jan 30 04:21:42 PST 2020
GeoSites is no longer maintained for the recent stable versions and also not available to the regular and SPC docker composition. However, multitenancy might be accomplished without huge effort with Rancher too in case you don’t have a specific constraint to the same admin user. In fact each dockerized instance can be configured to work against an external LDAP server where the same users insist.
If you want to move forward the code of GeoSites we accept pull requests :), alternatively you can have a look to the professional support page.
Hope this helps,
Francesco
Il 30 gen 2020, 10:16 +0100, Dev Gis <deviirmr at gmail.com>, ha scritto:
> Dear GeoNode user,
> Do you know how to implement GeoNode multi-tenancy in a docker environment?
> I want to implement multiple websites which point to the same GeoNode resources.
> On google search, I found only http://docs.geonode.org/en/2.8.1/reference/developers/geosites.html which is not specific to docker.
> Thanks
> Deb
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200130/5ebcb588/attachment.html>
More information about the geonode-users mailing list
