[GeoNode-users] Unable to upgrade the GeoNode Docker instaces.
Dev Gis deviirmr at gmail.com
Fri Jul 31 03:40:42 PDT 2020
Thank you for coming to help.
I just check it says, master
[image: image.png]
Regards
Deb
On Fri, Jul 31, 2020 at 12:35 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Are you sure /usr/src/geonode branch is 3.x or master?
> You must change geonode branch in order to get the latest changed of
> course.
> Try this command in order to check the branch name,
> git branch
> Il giorno ven 31 lug 2020 alle ore 12:19 Dev Gis <deviirmr at gmail.com> ha
> scritto:
>> Hello,
>> I hope you all are staying safe and healthy through these unusual times!
>> Has anybody tried to upgrade the old GeoNode docker instances to the
>> latest one?
>>  I have an old Geonode instance of version 3.0.0.dev1588342607) which I
>> want to upgrade to the latest one. I follow the steps mentioned in the
>> link
>> <https://docs.geonode.org/en/master/install/basic/#update-geonode-core-to-the-latest-commit>.
>> I execute the all steps without any error but still, I don't see any update
>> on the interface.
>>  I really like the data style editor which is missing at 3.0 instances.
>> Any suggestion?
>> Regards
>> Deb
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200731/86d0d949/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200731/86d0d949/attachment.png>
More information about the geonode-users mailing list
