[GeoNode-users] error install ubuntu 18.04
Muhammad Iqbal Firdaus muh.firdausiqbal at gmail.com
Tue Jun 23 05:34:24 PDT 2020
Dear Rizky,
Yes you're right, i'm in Sumatera now :). Thanks for your suggestion
previously, i wish the best of luck for you too!
Regards,
Iqbal
On Tue, Jun 23, 2020 at 11:37 AM <rizky at kartoza.com> wrote:
> Hi Iqbal,
> I’m glad that you have resolved this.
> Based on your name, and your exact problem, I just thought that maybe you
> are Indonesian? CMIIW.
> I have had similar issue in the past due to the ISP (I am using Ind*h*me).
> That’s why in the previous reply I suggest you to check the network
> (unrelated with GeoNode).
> This problem is a little bit random due to the ISP routing. Sometimes you
> can connect, sometimes don’t. Using VPN is a good idea (I also set up VPN).
> We can conclude this issue as resolved. Best of luck!
> Regards,
> Rizky Maulana Nugraha
> *From: *Muhammad Iqbal Firdaus <muh.firdausiqbal at gmail.com>
> *Sent: *Sunday, June 21, 2020 3:40 PM
> *To: *geonode-users at lists.osgeo.org
> *Subject: *Re: [GeoNode-users] error install ubuntu 18.04
> Hello,
> Apologize, maybe this email finds as duplicate post for previous thread
> from my question about installation geonode in Ubuntu. I would just to let
> you know, that the installation of geonode docker-build.sh in my device is
> encountered error due to network from ISP (i believe). the result i get i
> compare between Ubuntu Linux Desktop (Failed install) and Server
> (Successfully installed) previously, using different laptop. The one that
> success is using VPN, while the failed one is not using VPN. I just
> realized, when i also trying to install docker-build.sh (geonode) in ubuntu
> server, without VPN is encountered error persists with the previously
> installing in ubuntu desktop. Hence, i think the problem is with the
> network with VPN is more secure and importantly uninterrupted installation
> process when getting the archive from ubuntu server.
> Here it is the installation process when using VPN, sucessfully installed
> i guest.
> Regards
> Iqbal
> On Thu, Jun 18, 2020 at 10:56 AM Muhammad Iqbal Firdaus <
> muh.firdausiqbal at gmail.com> wrote:
> Dear Geonode masters,
> I'm new at geonode installation and encourage to dive and understand
> geonode usage and development, however when i try to install geonode i get
> the following error message, when installing the shell script based on the
> installation documentation (Geonode Basic) for geonode 3. Here is the error:
> E: Failed to fetch http://deb.debian.org/debian/pool/main/a/armadillo/li
>             barmadillo9_9.200.7+dfsg-1_amd64.deb  Connection failed [IP:
> 151.101.8.2
>                         04 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/b/boost1.67/li
>             bboost1.67-dev_1.67.0-13+deb10u1_amd64.deb  Connection failed
> [IP: 151.1
>                         01.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/c/charls/libch
>             arls-dev_2.0.0+dfsg-1_amd64.deb  Connection failed [IP:
> 151.101.8.204 80
> E: Failed to fetch http://deb.debian.org/debian/pool/main/j/json-c/libjs
>             on-c3_0.12.1+ds-2_amd64.deb  Connection failed [IP:
> 151.101.8.204 80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/o/ogdi-dfsg/li
>             bogdi3.2_3.2.1+ds-4_amd64.deb  Connection failed [IP:
> 151.101.8.204 80]
>             bogdi3.2-dev_3.2.1+ds-4_amd64.deb  Connection failed [IP:
> 151.101.8.204
>                            80]
> E: Failed to fetch http://deb.debian.org/debian/pool/main/libm/libmemcac
>             hed/libhashkit2_1.0.18-4.2_amd64.deb  Connection failed [IP:
> 151.101.8.2
>                         04 80]
> E: Failed to fetch http://apt.postgresql.org/pub/repos/apt/pool/main/p/p
>             ostgresql-common/postgresql-client-common_215.pgdg100+1_all.deb
>  Connect
>                       ion failed [IP: 217.196.149.55 80]
> E: Unable to fetch some archives, maybe run apt-get update or try with -
>           -fix-missing?
> ERROR: Service 'django' failed to build: The command '/bin/sh -c apt-get
>            update && apt-get install -y           gcc                 zip
>      g
>                     ettext          postgresql-client-11 libpq-dev
>  sqlite3 spatiali
>                               te-bin libsqlite3-mod-spatialite
>     python3-gdal python3-ps
>                                         ycopg2 python3-ldap
> python3-pil python3-lxml python3-pyl
>                                                   ibmc
> python3-dev libgdal-dev                 libxml2 lib
>        xml2-dev
> libxslt1-dev zlib1g-dev libjpeg-dev                 libmemcache
> d-dev libsasl2-dev                 libldap2-dev libsasl2-dev
>                uwsgi uwsgi-plugin-python3         --no-install-recommends
> && rm -r
>                         f /var/lib/apt/lists/*' returned a non-zero code:
> 100
> WARNING! This will remove:
>   - all stopped containers
>   - all networks not used by at least one container
>   - all images without at least one container associated to them
>   - all build cache
> Are you sure you want to continue? [y/N]
> if i type y then the installation is aborted and canceled, i suspect that
> the error is because the file packag is not found. Do you know how to
> figure out to fix this?
> do i have to check the advance installation, and do one by one
> installation based on script,?
> Thanks in advance
> Regards,
> Iqbal
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200623/b0ead93b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200623/b0ead93b/attachment-0001.png>
More information about the geonode-users mailing list
