[GeoNode-users] updatelayers "httplib2.socks.HTTPError: (403, 'Forbidden')" problem ...
Giuliano Grigolin
giuliano.geobases at gmail.com
Thu Mar 19 13:33:45 PDT 2020
Hi all !
I have a GeoNode 2.8 in production, with internet domain, in Ubuntu Server
16.04.
When i try update a layer that i import trough "Import Data" in GeoServer,
i get the following message:
root at geonode# python manage.py updatelayers -w geonode -f
my_layer_in_GeoServer
Inspecting the available layers in GeoServer ...
GET http://localhost:8080/geoserver/rest/workspaces.xml
File "manage.py", line 11, in <module>
execute_from_command_line(sys.argv)
File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line
utility.execute()
File
346, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
self.execute(*args, **cmd_options)
line 445, in execute
output = self.handle(*args, **options)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
line 122, in handle
execute_signals=True)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
531, in gs_slurp
workspace = cat.get_workspace(workspace)
File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 1031,
in get_workspace
workspaces = self.get_workspaces(name)
File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 1011,
in get_workspaces
description = self.get_xml("%s/workspaces.xml" % self.service_url)
File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 211,
in get_xml
response, content = self.http.request(rest_url)
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1659,
in request
(response, content) = self._request(conn, authority, uri, request_uri,
method, body, headers, redirections, cachekey)
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1399,
in _request
(response, content) = self._conn_request(conn, request_uri, method,
body, headers)
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1319,
in _conn_request
conn.connect()
File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 946,
in connect
self.sock.connect((self.host, self.port) + sa[2:])
File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 434, in
connect
self.__negotiatehttp(destpair[0], destpair[1])
File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 400, in
__negotiatehttp
raise HTTPError((statuscode, statusline[2]))
The 'importlayers' command returns an 403 error message too:
python manage.py importlayers -v 3 /mnt/GEOSRVVOL01/000-transf/34_787_test/
Verifying that GeoNode is running ...
Found 1 potential layers.
Using name as requested
In pre_save_layer
instance.alternate is: geonode:_34_787_test
Checking for permissions.
There are no permissions for this object, setting default perms.
Inside set_geofence_all for instance geonode:_34_787_test
going to work in workspace 'geonode'
Attempt 1/5 - Found layer in the database
>>> Step 2. Make sure we are not trying to overwrite a existing resource
named [_34_787_test] with the wrong type
[failed] Layer for
'/mnt/GEOSRVVOL01/000-transf/34_787_test/34_787_test.shp' (1/1)
Detailed report of failures:
File "/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py",
line 778, in upload
charset=charset)
line 553, in file_upload
defaults=defaults
File "/usr/lib/python2.7/dist-packages/django/db/models/manager.py", line
127, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/modeltranslation/manager.py", line
389, in get_or_create
return super(MultilingualQuerySet, self).get_or_create(**kwargs)
File "/usr/lib/python2.7/dist-packages/django/db/models/query.py", line
407, in get_or_create
return self._create_object_from_params(lookup, params)
439, in _create_object_from_params
obj = self.create(**params)
381, in create
return super(MultilingualQuerySet, self).create(**kwargs)
348, in create
obj.save(force_insert=True, using=self.db)
File "/usr/lib/python2.7/dist-packages/polymorphic/models.py", line 74,
in save
return super(PolymorphicModel, self).save(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line
734, in save
force_update=force_update, update_fields=update_fields)
771, in save_base
update_fields=update_fields, raw=raw, using=using)
File "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
line 189, in send
response = receiver(signal=self, sender=sender, **named)
File "/usr/local/lib/python2.7/dist-packages/geonode/decorators.py", line
44, in wrapper
return func(*args, **kwargs)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
87, in geoserver_post_save
producer.geoserver_upload_layer(payload)
File "<decorator-gen-3>", line 2, in geoserver_upload_layer
File
"/usr/local/lib/python2.7/dist-packages/geonode/messaging/producer.py",
line 62, in sync_if_local_memory
worker.run()
File "/usr/lib/python2.7/dist-packages/kombu/mixins.py", line 170, in run
for _ in self.consume(limit=None, **kwargs):
File "/usr/lib/python2.7/dist-packages/kombu/mixins.py", line 192, in
consume
conn.drain_events(timeout=safety_interval)
File "/usr/lib/python2.7/dist-packages/kombu/connection.py", line 301, in
drain_events
return self.transport.drain_events(self.connection, **kwargs)
File "/usr/lib/python2.7/dist-packages/kombu/transport/virtual/base.py",
line 961, in drain_events
get(self._deliver, timeout=timeout)
File "/usr/lib/python2.7/dist-packages/kombu/utils/scheduling.py", line
56, in get
return self.fun(resource, callback, **kwargs)
line 999, in _drain_channel
return channel.drain_events(callback=callback, timeout=timeout)
line 745, in drain_events
return self._poll(self.cycle, callback, timeout=timeout)
line 402, in _poll
return cycle.get(callback)
56, in get
line 406, in _get_and_deliver
callback(message, queue)
line 981, in _deliver
callback(message)
line 633, in _callback
return callback(message)
File "/usr/lib/python2.7/dist-packages/kombu/messaging.py", line 624, in
_receive_callback
return on_m(message) if on_m else self.receive(decoded, message)
File "/usr/lib/python2.7/dist-packages/kombu/messaging.py", line 590, in
receive
[callback(body, message) for callback in callbacks]
File
"/usr/local/lib/python2.7/dist-packages/geonode/messaging/consumer.py",
line 99, in on_geoserver_messages
geoserver_post_save_local(layer)
File
130, in geoserver_post_save_local
charset=instance.charset)
File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/upload.py", line
71, in geoserver_upload
workspace = cat.get_workspace(settings.DEFAULT_WORKSPACE)
in get_workspace
in get_workspaces
in get_xml
in request
in _request
body, headers)
in _conn_request
conn.connect()
in connect
connect
__negotiatehttp
Finished processing 1 layers in 3.0 seconds.
0 Created layers
0 Updated layers
0 Skipped layers
1 Failed layers
3.000000 seconds per layer
Any tip on where is the prmission issue ?
Thanks
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200319/84971194/attachment-0001.html>
More information about the geonode-users
