[GeoNode-users] migration suggestions
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Sat Mar 21 05:45:46 PDT 2020
Hi Eugenio,
I would need to have a look what is going on. But yes local_settings should override settings.
The correct command for migrations is python manage.py migrate ... (instead of syncdb)
best regards
toni
> Am 20.03.2020 um 19:58 schrieb Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear Toni,
> I followed your hints.
> I put the domain in the ALLOWED_HOSTS and now I visualise the home page.
> Just a question, I had to put the domain the settings.py file because it didn't work in local_setting.py, why? Don't local_setting override setting.py?
> Then I modify local_setting.py to set credential to access geonode db.
> Then I alter the table you suggested and I run python manage.py --syncdb but the number of tables didn't change, is that correct?
> The geonode home page is visualised but I'm not able to enter with the old administrator credential.
> I presume there is no connection with the db. Should I use again setting.py instead of local_setting.py?
> Thanks in advance,
> Eugenio
> Da: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> Inviato: giovedì 19 marzo 2020 20:37
> A: Eugenio Trumpy <frippe12573 at hotmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Oggetto: Re: migration suggestions
> Dear Eugenio,
> > • I set the wgsi module in apache2. The geonode is served now with the 'allowed_hosts' error. I think the issue could be related to the settings. In the 2.4 version I remember I set SITE_URL, should I set something similar even in this version?
> Allowed hosts is a security mechanism by Django to define Domains that serve your instance.
> https://docs.djangoproject.com/en/3.0/ref/settings/#allowed-hosts <https://docs.djangoproject.com/en/3.0/ref/settings/#allowed-hosts>
> To overcome an 504 error you can add something like
> ALLOWED_HOSTS = ['localhost' '127.0.0.1' 'your domain.com']
> to your settings.py or local_settings.p However, we all more and more avoid touching the settings file and try to configure everything
> with environment variables. So with a manual setup you can try to add it to your uwsgi config:
> https://docs.geonode.org/en/master/install/core/index.html#serving-geonode-geoserver-via-nginx <https://docs.geonode.org/en/master/install/core/index.html#serving-geonode-geoserver-via-nginx>
> > • I created a geonode postgresql empty db, while I restored the backup from that I was using in 2.4 version. How I should populate with the new data-schema the geonode metadata db? I remember there was the command python manage.py --syncdb, does still exist? I tried but I got error.
> I'm unsure If I correctly understand. But the rough flow looks like:
> • Export your geonode 2.4 Database
> • Import it to a fresh Database
> • Be sure to correctly set permissions for your User
> • Change your settings.py for using the new database and in case the correct user
> • Fix some inconsistency within your new database. Run f.e. with pgadmin or by psql from console
> • ALTER TABLE public.layers_layer DROP COLUMN service_id
> • Run the migrations, this should update your database scheme from 2.4 to 2.10
> • DJANGO_SETTINGS_MODULE=YOURGEONODE.local_settings django python manage.py migrate --fake-initial
> You will need to change those commands to fit your setup further run into errors here and
> there but hopefully this steps help you to find out of the forest.
> Cheers,
> Toni
> CSGIS
> Spinnereistraße 7
> Halle 18 04179 Leipzig
> Web https://csgis.de <https://csgis.de/>
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200321/1ede60fa/attachment.html>
More information about the geonode-users
