[GeoNode-users] migration suggestions
    Toni Schönbuchner
    toni.schoenbuchner at csgis.de
    Sat Mar 21 06:30:43 PDT 2020
Dear Eugenio,
first of all, please be prepared that a migration is not a walk in the park.
You might need some background knowledge about the db scheme and how
is everything is wired together. Further I think the whole multisites idea is not
maintained since long time and hence I would suggest that you first try to port your
data to a single site 2.10.3 instance.
You're saying them amount of tables changed after running migrate? That
is a good sign. The most interesting here is if the manage command threw errors?
Further yes, a wrong settings file could lead to a wrong database usage.
(Just rename the old and you will see ;)
In case of geonode_project you can try to set local_settings here.
https://github.com/GeoNode/geonode-project/blob/2.10.3/project_name/wsgi.py#L38 <https://github.com/GeoNode/geonode-project/blob/2.10.3/project_name/wsgi.py#L38>
Best regards
Toni
> Am 21.03.2020 um 14:20 schrieb Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear Toni,
> thank you to have answered to mail last email.
> My situation is the following:
> I have a geonode 2.4 running on a server 'A' configured to run as multi-site which embeds something like 120 layers, 20 maps and 3 users. In server 'A' is running ubuntu 14.04, which is obsolete.
> I have also server 'B' where ubuntu is at the version 18.04.
> I want to migrate my genode 2.4 running instance as multisites from server 'A' to 'B'.
> I have asked some weeks ago here in the list what would have been the best solution, consider I'm not a developer and I never used the virtualenv. I installed the 2.4 version for production.
> For the migration I was following some suggestions from Alessio:
> Setup a new GeoServer 2.15.2 ( https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.15.2.war <https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.15.2.war> )
> Transfer the Data Dir from the old GeoServer to the new one (I strongly suggest to backport **only** the workspace, datasets and styles, not the security subsystem)
> Setup the new GeoNode instance
> Run the "updatelayers" management command (see http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#management-command-updatelayers <http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#management-command-updatelayers> )
> Update manually the missing permissions and metadata
> I completed step 1 with geoserver 2.16.2 - I installed the data_dir outside geoserver - and it runs fine
> I completed step 2 and I'm able to see all the layers I had in server 'A'
> I set up a fresh geonode instance, even thanks to you help. I installed geonode from GIT, so I should have the master version (2.10).
> Within the step 2 I restored in server 'A' the two postgresql db I had inserver 'A'
> Since I remembered some steps of the custom configuration I did for version 2.4 (and I never used NGINX) I configured APACHE2.
> Currently in server 'B' I'm able to see the geonode home page, but I cannot see my layers as well as I cannot enter as administrator.
> I followed you suggestions and I
> ALTER TABLE public.layers_layer DROP COLUMN service_id
> successfully
> and I gave the command
> django python manage.py migrate --fake-initial
> but I'm still not able to enter as administrator
> I realized even that the db schema apparently didn't change (e.g. I had 75 tables in the old version and I still have 75 tables in the newer version, I don't if the fields are modified instead)
> to have the version 2.10 running I followed your suggestion to insert my domain in the ALLOWED_HOSTS variable inside local_settings.py. I did it but it didn't work as long as I insert the same in settings.py. For this reason I'm supposing that local_settings.py is not active in some way and for the same reason it doesn't allow to connect to the db. Am I right?
> Once the administrator login will be solved:
> I should configure this new running geonode instance for multisites - Could I restore in someway the look & feels I had in the old instance?
> check the authorization between geonode and geoserver
> I hope this can help you to have a clearer vision of 'whats going on'...
> Best regards,
> Eugenio
> Da: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> Inviato: sabato 21 marzo 2020 13:45
> A: Eugenio Trumpy <frippe12573 at hotmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Oggetto: Re: migration suggestions
> Hi Eugenio,
> I would need to have a look what is going on. But yes local_settings should override settings.
> The correct command for migrations is python manage.py migrate ... (instead of syncdb)
> best regards
> toni
>> Am 20.03.2020 um 19:58 schrieb Eugenio Trumpy <frippe12573 at hotmail.com <mailto:frippe12573 at hotmail.com>>:
>> Dear Toni,
>> I followed your hints.
>> I put the domain in the ALLOWED_HOSTS and now I visualise the home page.
>> Just a question, I had to put the domain the settings.py file because it didn't work in local_setting.py, why? Don't local_setting override setting.py?
>> Then I modify local_setting.py to set credential to access geonode db.
>> Then I alter the table you suggested and I run python manage.py --syncdb but the number of tables didn't change, is that correct?
>> The geonode home page is visualised but I'm not able to enter with the old administrator credential.
>> I presume there is no connection with the db. Should I use again setting.py instead of local_setting.py?
>> Thanks in advance,
>> Eugenio
>> Da: Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>>
>> Inviato: giovedì 19 marzo 2020 20:37
>> A: Eugenio Trumpy <frippe12573 at hotmail.com <mailto:frippe12573 at hotmail.com>>
>> Cc: geonode-users <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
>> Dear Eugenio,
>> >        • I set the wgsi module in apache2. The geonode is served now with the 'allowed_hosts' error. I think the issue could be related to the settings. In the 2.4 version I remember I set SITE_URL, should I set something similar even in this version?
>> Allowed hosts is a security mechanism by Django  to define Domains that serve your instance.
>> https://docs.djangoproject.com/en/3.0/ref/settings/#allowed-hosts <https://docs.djangoproject.com/en/3.0/ref/settings/#allowed-hosts>
>> To overcome an 504 error you can add something like
>> ALLOWED_HOSTS = ['localhost' '127.0.0.1' 'your domain.com <http://domain.com/>']
>> to your settings.py or local_settings.p However, we all more and more avoid touching the settings file and try to configure everything
>> with environment variables. So with a manual setup you can try to add it to your uwsgi config:
>> https://docs.geonode.org/en/master/install/core/index.html#serving-geonode-geoserver-via-nginx <https://docs.geonode.org/en/master/install/core/index.html#serving-geonode-geoserver-via-nginx>
>> >        • I created a geonode postgresql empty db, while I restored the backup from that I was using in 2.4 version. How I should populate with the new data-schema the geonode metadata db? I remember there was the command python manage.py --syncdb, does still exist? I tried but I got error.
>> I'm unsure If I correctly understand. But the rough flow looks like:
>>         • Export your geonode 2.4 Database
>>         • Import it to a fresh Database
>>         • Be sure to correctly set permissions for your User
>>         • Change your settings.py for using the new database and in case the correct user
>>         • Fix some inconsistency within your new database. Run f.e. with pgadmin or by psql from console
>>                 • ALTER TABLE public.layers_layer DROP COLUMN service_id
>>         • Run the migrations, this should update your database scheme from 2.4 to 2.10
>>                 • DJANGO_SETTINGS_MODULE=YOURGEONODE.local_settings django python manage.py migrate --fake-initial
>> You will need to change those commands to fit your setup further run into errors here and
>> there but hopefully this steps help you to find out of the forest.
>> Cheers,
>> Toni
>> CSGIS
>> Spinnereistraße 7
>> Halle 18 04179 Leipzig
>> Web             https://csgis.de <https://csgis.de/>
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200321/be492623/attachment-0001.html>
More information about the geonode-users
