[GeoNode-users] GeoNode Feature Freeze and Release Process
1520 gis
juliermeopensourcedeveloper at gmail.com
Sat May 9 17:23:46 PDT 2020
Hi Alessio,
When you mean testing, is it just to check any bug with the docker and
virtualenv installation process and features functionality?
Do you have a list of geonode features that we are supposed to check? If so
could you share it?
Kind regards
Julierme
On Fri, May 8, 2020 at 6:57 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> as discussed internally with the PSC, we are starting the release process
> for
> - GeoNode 3.0
> - GeoNode 2.10.4
> Therefore we are calling a feature freeze until the release has been done.
> Any help testing the release candidates, branches master and 2.10.x, are
> very welcome and appreciated.
> Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200509/1c65d4bd/attachment.html>
More information about the geonode-users
