[GeoNode-users] Define email service on GeoNode
Jose Cáceres jose.atyus at gmail.com
Fri May 22 09:56:05 PDT 2020
Hi Alessio,
Thanks for your advice, I added the variables to the django image on the
docker-compose file, without the quotation but I ended up with a 502 error
on my site, removing those variables from the docker file let me have the
site backup, so here is definitely something related to added those
variables.
I'll keep working on it and see if I can find the problem.
Thanks,
José
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
22/05/20
10:54:34
On Fri, May 22, 2020 at 1:46 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Jose,
> in GeoNode the recommended way is to use environment variables always.
> There is logic on original settings which depends on some env values. That
> means that it is not simply matter to override a variable sometimes.
> In your case I guess the error is that the values of end on docker-compose
> and uwsgi do not require quotes nor double quotes except in very special
> cases when you have characters that conflicts with the shell.
> -A.
> Il giorno gio 21 mag 2020 alle ore 23:38 Jose Cáceres <
> jose.atyus at gmail.com> ha scritto:
>> Hi,
>> I'm running Geonode on Docker.
>> I'm having troubles configuring the mail service for Geonode. I was able
>> to have it up and running by defining the values directly on my settings.py
>> file, like this:
>> *EMAIL_ENABLE = ast.literal_eval(os.getenv('EMAIL_ENABLE', 'True'))if
>> EMAIL_ENABLE:    EMAIL_BACKEND = os.getenv('DJANGO_EMAIL_BACKEND',
>>                     default='django.core.mail.backends.smtp.EmailBackend')
>>   EMAIL_HOST = os.getenv('DJANGO_EMAIL_HOST', '*smtp.gmail.com
>> *')    EMAIL_PORT = os.getenv('DJANGO_EMAIL_PORT', 587)
>> EMAIL_HOST_USER = os.getenv('DJANGO_EMAIL_HOST_USER', 'my_mail at gmail.com
>> <my_mail at gmail.com>')    EMAIL_HOST_PASSWORD =
>> os.getenv('DJANGO_EMAIL_HOST_PASSWORD', 'mypassword')    EMAIL_USE_TLS =
>> ast.literal_eval(os.getenv('DJANGO_EMAIL_USE_TLS', 'True'))
>> DEFAULT_FROM_EMAIL = os.getenv('DEFAULT_FROM_EMAIL', 'GeoNode
>> <no-reply at geonode.org <no-reply at geonode.org>>')else:    EMAIL_BACKEND =
>> default='django.core.mail.backends.console.EmailBackend')*
>> This way I was able to deliver messages to users, send notifications, etc.
>> But I don't want to have those values available on the settings.py, so I
>> figure I could add the variales to my docker-compose file, like this:
>> *DJANGO_EMAIL_HOST='smtp.gmail.com
>> <http://smtp.gmail.com>'DJANGO_EMAIL_PORT=587DJANGO_EMAIL_HOST_USER='my_mail at gmail.com
>> <my_mail at gmail.com>'DJANGO_EMAIL_HOST_PASSWORD='my password'*
>> And I left the values on the settings.py by default:
>> *EMAIL_ENABLE = ast.literal_eval(os.getenv('EMAIL_ENABLE', 'False'))if
>>   EMAIL_HOST = os.getenv('DJANGO_EMAIL_HOST', 'localhost')    EMAIL_PORT =
>> os.getenv('DJANGO_EMAIL_PORT', 25)    EMAIL_HOST_USER =
>> os.getenv('DJANGO_EMAIL_HOST_USER', '')    EMAIL_HOST_PASSWORD =
>> os.getenv('DJANGO_EMAIL_HOST_PASSWORD', '')    EMAIL_USE_TLS =
>> ast.literal_eval(os.getenv('DJANGO_EMAIL_USE_TLS', 'False'))
>> But this way is not working, messages are not sent.
>> So I want to ask you what is the best way to configure the mail service.
>> Thanks in advanced.
>> José
>> José David Cáceres
>> Ingeniero Ambiental
>> Máster en Tecnologías de la Información Geográfica
>> e-mail: jose.atyus at gmail.com
>> [image: Mailtrack]
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
>> notificado con
>> Mailtrack
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 21/05/20
>> 15:36:45
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
José David Cáceres
Ingeniero Ambiental
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200522/62674bc4/attachment.html>
More information about the geonode-users mailing list
