[GeoNode-users] GeoNode-Project Docker Postgres Access
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Nov 30 01:56:02 PST 2020
Hi Irlan,
1) About the external DB, you need to initialize it accordingly to the
guidelines depicted here
https://docs.geonode.org/en/master/install/advanced/core/index.html#postgis-database-setup
  Then you just need to updated your DB name, user, pwd and host
accordingly into the .env files
2) About that file, you need to modify it inside the GeoServer docker
static volume. It is located into the "/geoserver_data_dir/data/geofence"
folder
You can safely use Postgresql > 11
Il giorno lun 30 nov 2020 alle ore 05:05 irlan128 <irlan128 at gmail.com> ha
scritto:
> Dear Alessio,
> I add this script to my django.env file, but i dont know where i must to
> put/write my IP address my server postgresql in that command/script
> (because
> my postgresql is  in the outside docker and different server)?
> geofenceVendorAdapter.databasePlatform=org.hibernatespatial.postgis.PostgisDialect
> geofenceDataSource.driverClassName=org.postgresql.Driver
> geofenceDataSource.url=jdbc:postgresql://db:5432/geonode_data
> geofenceDataSource.username=geonode_data
> geofenceDataSource.password=geonode_data
> geofenceEntityManagerFactory.jpaPropertyMap[hibernate.default_schema]=public
> I want to ask, is there any issue of using postgresql 12?because when i see
> the postgresql in container (db4geonode), the version of postgresql is 11
> Thanks
> Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201130/1e1d1675/attachment.html>
More information about the geonode-users mailing list
