[GeoNode-users] Newbie / Evaluating GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Oct 20 02:28:43 PDT 2020
Hello Mike,
GeoNode relies on the GeoSpatial server in order to manage the projections.
Also on the frontend, the client is pluggable.
So, long story short, this is all customizable. By default, GeoNode
provides GeoServer, as geospatial backend, and MapStore2 as gis client,
which uses mercator as default projection.
That said when you upload a new layer, GeoNode checks for a valid
projection file. It tried to keep the native projection on the backend
whenever is possible.
In the case it cannot find it, it asks to the user to specify a valid
native projection for the data.
The available choices must be configured on the GeoNode settings. The
default ones are the following
https://docs.geonode.org/en/master/basic/settings/index.html#epsg-code-matches
'EPSG:4326': '(4326) WGS 84',
'EPSG:900913': '(900913) Google Maps Global Mercator',
'EPSG:3857': '(3857) WGS 84 / Pseudo-Mercator',
'EPSG:3785': '(3785 DEPRECATED) Popular Visualization CRS / Mercator',
'EPSG:32647': '(32647) WGS 84 / UTM zone 47N',
'EPSG:32736': '(32736) WGS 84 / UTM zone 36S'}
Il giorno mar 20 ott 2020 alle ore 11:20 Mike Saunt <
mikesaunt at astuntechnology.com> ha scritto:
> Hi all!
> I was wondering whether GeoNode keeps all data in it's source projection
> (or the user can specify the projection if creating a layer)?
> If yes then I presume "All the layers are automatically re-projected to
> web Mercator for maps display, making it possible to use different popular
> base layers, like Open Street Map, Google Satellite or Bing layers." from this
> GeoNode help page
> <https://docs.geonode.org/en/master/start/#data-mixing-maps-creation> is
> simply done dynamically with JavaScript in the browser?
> Many thanks
> Mike
> Mike Saunt
> *Sign up to our mailing list
> <https://astuntechnology.com/company/#email-updates> for updates on news,
> products, conferences, events and training*
> Astun Technology Ltd, Epsom Square Centre, 6-7 The Derby Square, Epsom,
> Surrey, KT19 8AG, UK
> t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
> <https://twitter.com/astuntech>
> iShare - enterprise geographic intelligence platform
> <https://astuntechnology.com/ishare/>
> GeoServer, PostGIS and QGIS training
> <https://astuntechnology.com/training-courses/>
> Helpdesk and customer portal
> <https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal>
> Company registration no. 5410695. Registered in England and Wales.
> Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
> 864201149.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201020/9ccb6fb3/attachment-0001.html>
More information about the geonode-users
