[GeoNode-users] Newbie / Evaluating GeoNode
Jose Cáceres
jose.atyus at gmail.com
Tue Oct 20 06:25:54 PDT 2020
Hi Mike,
Just yo follow Up on your other questions, you can use any of the base maps
you mentioned, OSM is included by default, but you can add your token for
Bing Maps, Mapbox, etc., to your settings file and they will be display in
all your maps and you will be able to choose wich base map you want to use.
Kind regards
El mar., 20 oct. 2020 4:26 a. m., Mike Saunt <mikesaunt at astuntechnology.com>
escribió:
> Thanks Alessio
> I think that's the answer I'm after - quick summary being:
> GeoNode can be configured to store data (via GeoServer / PostGIS) in
> say EPSG:27700 Projected coordinate system for United Kingdom (UK) and
> displayed in the same projection via the browser .
> Thanks
> On Tue, 20 Oct 2020 at 10:28, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Mike,
>> GeoNode relies on the GeoSpatial server in order to manage the
>> projections. Also on the frontend, the client is pluggable.
>> So, long story short, this is all customizable. By default, GeoNode
>> provides GeoServer, as geospatial backend, and MapStore2 as gis client,
>> which uses mercator as default projection.
>> That said when you upload a new layer, GeoNode checks for a valid
>> projection file. It tried to keep the native projection on the backend
>> whenever is possible.
>> In the case it cannot find it, it asks to the user to specify a valid
>> native projection for the data.
>> The available choices must be configured on the GeoNode settings. The
>> default ones are the following
>> https://docs.geonode.org/en/master/basic/settings/index.html#epsg-code-matches
>> 'EPSG:4326': '(4326) WGS 84',
>> 'EPSG:900913': '(900913) Google Maps Global Mercator',
>> 'EPSG:3857': '(3857) WGS 84 / Pseudo-Mercator',
>> 'EPSG:3785': '(3785 DEPRECATED) Popular Visualization CRS / Mercator',
>> 'EPSG:32647': '(32647) WGS 84 / UTM zone 47N',
>> 'EPSG:32736': '(32736) WGS 84 / UTM zone 36S'}
>> Il giorno mar 20 ott 2020 alle ore 11:20 Mike Saunt <
>> mikesaunt at astuntechnology.com> ha scritto:
>>> Hi all!
>>> I was wondering whether GeoNode keeps all data in it's source projection
>>> (or the user can specify the projection if creating a layer)?
>>> If yes then I presume "All the layers are automatically re-projected to
>>> web Mercator for maps display, making it possible to use different popular
>>> base layers, like Open Street Map, Google Satellite or Bing layers." from this
>>> GeoNode help page
>>> <https://docs.geonode.org/en/master/start/#data-mixing-maps-creation>
>>> is simply done dynamically with JavaScript in the browser?
>>> Many thanks
>>> Mike
>>> Mike Saunt
>>> *Sign up to our mailing list
>>> <https://astuntechnology.com/company/#email-updates> for updates on news,
>>> products, conferences, events and training*
>>> Astun Technology Ltd, Epsom Square Centre, 6-7 The Derby Square, Epsom,
>>> Surrey, KT19 8AG, UK
>>> t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
>>> <https://twitter.com/astuntech>
>>> iShare - enterprise geographic intelligence platform
>>> <https://astuntechnology.com/ishare/>
>>> GeoServer, PostGIS and QGIS training
>>> <https://astuntechnology.com/training-courses/>
>>> Helpdesk and customer portal
>>> <https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal>
>>> Company registration no. 5410695. Registered in England and Wales.
>>> Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
>>> 864201149.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> Mike Saunt
> 864201149.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20201020/6eb61fbb/attachment-0001.html>
More information about the geonode-users
