[GeoNode-users] Installing Geonode from advanced core ubuntu-18-04 and requirements.txt issues
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Sep 14 03:08:48 PDT 2020
Hi Davide,
it looks correct to me.
That part of the documentation is a bit outdated and it is very possible
that the procedures must be revised a bit.
It would very helpful if you could do a pull request here
https://github.com/GeoNode/documentation
so that someone can test the changes on a clean environment and eventually
update the docs.
Thanks again for your effort,
Alessio.
Il giorno dom 13 set 2020 alle ore 16:49 Davide Marchi <danjde at msw.it> ha
scritto:
> Hi Devs,
> we are installing Geonode (and later Geoserver) on Ubuntu 18.04 using
> the "advanced core ubuntu-18-04" documentation-->
> https://docs.geonode.org/en/master/install/advanced/core/index.html#ubuntu-18-04
> (no docker).
> We have found some issues, related to the requirements version on file
> "requirements.txt",
> here any details:
> 1)
> # Install Openjdk
> sudo -i apt update
> sudo apt install openjdk-8-jdk-headless default-jdk-headless -y
> sudo update-java-alternatives --jre-headless --jre --set
> java-1.8.0-openjdk-amd64
> replaced with:
> # Install Openjdk
> sudo -i apt update
> sudo apt install openjdk-11-jdk-headless default-jdk-headless -y
> java-1.11.0-openjdk-amd64
> 2)
>    Downloading psycopg2-2.8.5.tar.gz (380 kB)
>       |████████████████████████████████| 380 kB 27.9 MB/s
>      ERROR: Command errored out with exit status 1:
>       command: /home/geonode/.virtualenvs/geonode/bin/python3 -c 'import
> sys, setuptools, tokenize; sys.argv[0] =
> '"'"'/tmp/pip-install-q9uqi6ap/psycopg2/setup.py'"'"';
> __file__='"'"'/tmp/pip-install-q9uqi6ap/psycopg2/setup.py'"'"';f=getattr(tokenize,
> '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"',
> '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))'
> egg_info --egg-base /tmp/pip-pip-egg-info-c1buzarp
>           cwd: /tmp/pip-install-q9uqi6ap/psycopg2/
>      Complete output (23 lines):
>      running egg_info
>      creating /tmp/pip-pip-egg-info-c1buzarp/psycopg2.egg-info
>      writing /tmp/pip-pip-egg-info-c1buzarp/psycopg2.egg-info/PKG-INFO
>      writing dependency_links to
> /tmp/pip-pip-egg-info-c1buzarp/psycopg2.egg-info/dependency_links.txt
>      writing top-level names to
> /tmp/pip-pip-egg-info-c1buzarp/psycopg2.egg-info/top_level.txt
>      writing manifest file
> '/tmp/pip-pip-egg-info-c1buzarp/psycopg2.egg-info/SOURCES.txt'
>      Error: pg_config executable not found.
>      pg_config is required to build psycopg2 from source.  Please add the
> directory
>      containing pg_config to the $PATH or specify the full executable
> path with the
>      option:
>          python setup.py build_ext --pg-config /path/to/pg_config build
>      or with the pg_config option in 'setup.cfg'.
>      If you prefer to avoid building psycopg2 from source, please install
> the PyPI
>      'psycopg2-binary' package instead.
>      For further information please check the 'doc/src/install.rst' file
> (also at
>      <https://www.psycopg.org/docs/install.html>).
> ERROR: Command errored out with exit status 1: python setup.py egg_info
> Check the logs for full command output.
> solved by installing "libpq-dev"
> Rif:
> https://stackoverflow.com/questions/11618898/pg-config-executable-not-found
> 3)
>    Downloading gunicorn-20.0.4-py2.py3-none-any.whl (77 kB)
>       |████████████████████████████████| 77 kB 42.3 MB/s
> ERROR: Could not find a version that satisfies the requirement
> ipython==7.17.0 (from -r requirements.txt (line 134)) (from versions:
> 0.10, 0.10.1, 0.10.2, 0.11, 0.12, 0.12.1, 0.13, 0.13.1, 0.13.2, 1.0.0,
> 1.1.0, 1.2.0, 1.2.1, 2.0.0, 2.1.0, 2.2.0, 2.3.0, 2.3.1, 2.4.0, 2.4.1,
> 3.0.0, 3.1.0, 3.2.0, 3.2.1, 3.2.2, 3.2.3, 4.0.0b1, 4.0.0, 4.0.1, 4.0.2,
> 4.0.3, 4.1.0rc1, 4.1.0rc2, 4.1.0, 4.1.1, 4.1.2, 4.2.0, 4.2.1, 5.0.0b1,
> 5.0.0b2, 5.0.0b3, 5.0.0b4, 5.0.0rc1, 5.0.0, 5.1.0, 5.2.0, 5.2.1, 5.2.2,
> 5.3.0, 5.4.0, 5.4.1, 5.5.0, 5.6.0, 5.7.0, 5.8.0, 5.9.0, 5.10.0,
> 6.0.0rc1, 6.0.0, 6.1.0, 6.2.0, 6.2.1, 6.3.0, 6.3.1, 6.4.0, 6.5.0,
> 7.0.0b1, 7.0.0rc1, 7.0.0, 7.0.1, 7.1.0, 7.1.1, 7.2.0, 7.3.0, 7.4.0,
> 7.5.0, 7.6.0, 7.6.1, 7.7.0, 7.8.0, 7.9.0, 7.10.0, 7.10.1, 7.10.2,
> 7.11.0, 7.11.1, 7.12.0, 7.13.0, 7.14.0, 7.15.0, 7.16.0, 7.16.1)
> ERROR: No matching distribution found for ipython==7.17.0 (from -r
> solved by:
> in requirements.txt, on line 134 put the value "ipython==7.17.0" to
> "ipython==7.16.0"
> 4)
> ERROR: After October 2020 you may experience errors when installing or
> updating packages. This is because pip will change the way that it
> resolves dependency conflicts.
> We recommend you use --use-feature=2020-resolver to test your packages
> with the new resolver before it becomes the default.
> dynamic-rest 1.9.6 requires inflection==0.3.1, but you'll have
> inflection 0.5.1 which is incompatible.
> Solution:
> pip install -r requirements.txt --upgrade --no-cache --no-cache-dir
> 5)
> after executing:
> pip install -e . --upgrade
> ipython==7.17.0 (from GeoNode==3.1.0.dev1599573837) (from versions:
> in "/opt/geonode/setup.cfg" put "ipython==7.17.0" to "ipython==7.16.0"
> Result:
> Successfully installed GeoNode coreapi-2.3.3 coreschema-0.0.4
> drf-extensions-0.6.0 drf-yasg-1.17.1 itypes-1.2.0 jinja2-2.11.2
> pip-20.2.2 ruamel.yaml-0.16.12 ruamel.yaml.clib-0.2.2 uritemplate-3.0.1
> 6)
> pygdal==.* (from versions: 1.8.1.0, 1.8.1.1, 1.8.1.2, 1.8.1.3, 1.8.1.5,
> 1.8.1.6, 1.9.2.0, 1.9.2.1, 1.9.2.3, 1.9.2.5, 1.9.2.6, 1.10.0.0,
> 1.10.0.1, 1.10.0.3, 1.10.0.5, 1.10.0.6, 1.10.1.0, 1.10.1.1, 1.10.1.3,
> 1.10.1.5, 1.10.1.6, 1.11.0.0, 1.11.0.1, 1.11.0.3, 1.11.0.5, 1.11.0.6,
> 1.11.1.0, 1.11.1.1, 1.11.1.3, 1.11.1.5, 1.11.1.6, 1.11.2.1, 1.11.2.3,
> 1.11.2.5, 1.11.2.6, 1.11.3.3, 1.11.3.5, 1.11.3.6, 1.11.4.3, 1.11.4.5,
> 1.11.4.6, 1.11.5.3, 1.11.5.5, 1.11.5.6, 2.0.0.3, 2.0.0.5, 2.0.0.6,
> 2.0.1.3, 2.0.1.5, 2.0.1.6, 2.0.2.3, 2.0.2.5, 2.0.2.6, 2.0.3.3, 2.0.3.5,
> 2.0.3.6, 2.1.0.3, 2.1.0.5, 2.1.0.6, 2.1.1.3, 2.1.1.5, 2.1.1.6, 2.1.2.3,
> 2.1.2.5, 2.1.2.6, 2.1.3.3, 2.1.3.5, 2.1.3.6, 2.2.0.3, 2.2.0.5, 2.2.0.6,
> 2.2.1.3, 2.2.1.5, 2.2.1.6, 2.2.2.3, 2.2.2.5, 2.2.2.6, 2.2.3.3, 2.2.3.5,
> 2.2.3.6, 2.2.4.3, 2.2.4.5, 2.2.4.6, 2.3.0.4, 2.3.0.5, 2.3.0.6, 2.3.1.4,
> 2.3.1.5, 2.3.1.6, 2.3.2.4, 2.3.2.5, 2.3.2.6, 2.3.3.6, 2.4.0.4, 2.4.0.5,
> 2.4.0.6, 2.4.1.4, 2.4.1.5, 2.4.1.6, 2.4.2.5, 2.4.2.6, 2.4.4.6, 3.0.0.5,
> 3.0.0.6, 3.0.1.5, 3.0.1.6, 3.0.2.6, 3.0.3.6, 3.0.4.6, 3.1.0.6, 3.1.1.6,
> 3.1.2.6)
> ERROR: No matching distribution found for pygdal==.*
> Solution:
> install from apt:
> "sudo apt install libgdal-dev"
> with effect:
> The following additional packages will be installed:
>    autotools-dev default-libmysqlclient-dev gir1.2-harfbuzz-0.0
> hdf5-helpers icu-devtools libaec-dev libarmadillo-dev libarpack2-dev
> libblas-dev libboost-dev
>    libboost1.65-dev libcurl4-gnutls-dev libdap-dev libdapserver7v5
> libepsilon-dev libfreexl-dev libfyba-dev libgeotiff-dev libgif-dev
> libglib2.0-bin
>    libglib2.0-dev libglib2.0-dev-bin libgraphite2-3 libgraphite2-dev
> libharfbuzz-dev libharfbuzz-gobject0 libharfbuzz-icu0 libharfbuzz0b
> libhdf4-alt-dev
>    libhdf5-cpp-100 libhdf5-dev libicu-dev libicu-le-hb-dev libicu-le-hb0
> libiculx60 libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev
> libjson-c-dev
>    libkml-dev libkmlconvenience1 libkmlregionator1 libkmlxsd1
> liblapack-dev libltdl-dev liblzma-dev libminizip-dev libmysqlclient-dev
> libnetcdf-dev
>    libogdi3.2-dev libopenjp2-7-dev libpcre16-3 libpcre3-dev libpcre32-3
> libpcrecpp0v5 libpng-dev libpng-tools libpoppler-dev
> libpoppler-private-dev
>    libqhull-dev libqhull-r7 libspatialite-dev libsqlite3-dev libssl-dev
> libsuperlu-dev libtiff-dev libtiff5-dev libtiffxx5 libtool
> liburiparser-dev libwebp-dev
>    libwebpdemux2 libwebpmux3 libxerces-c-dev libxml2-dev pkg-config
> unixodbc-dev uuid-dev
> The following NEW packages will be installed:
> libepsilon-dev libfreexl-dev libfyba-dev libgdal-dev libgeotiff-dev
> libgif-dev
>    libglib2.0-bin libglib2.0-dev libglib2.0-dev-bin libgraphite2-3
> libgraphite2-dev libharfbuzz-dev libharfbuzz-gobject0 libharfbuzz-icu0
> libharfbuzz0b
>    libhdf4-alt-dev libhdf5-cpp-100 libhdf5-dev libicu-dev
> libicu-le-hb-dev libicu-le-hb0 libiculx60 libjbig-dev libjpeg-dev
>    libjson-c-dev libkml-dev libkmlconvenience1 libkmlregionator1
> libkmlxsd1 liblapack-dev libltdl-dev liblzma-dev libminizip-dev
> libmysqlclient-dev
>    libnetcdf-dev libogdi3.2-dev libopenjp2-7-dev libpcre16-3 libpcre3-dev
> libpcre32-3 libpcrecpp0v5 libpng-dev libpng-tools libpoppler-dev
>    libpoppler-private-dev libqhull-dev libqhull-r7 libspatialite-dev
> libsqlite3-dev libssl-dev libsuperlu-dev libtiff-dev libtiff5-dev
> libtiffxx5 libtool
>    liburiparser-dev libwebp-dev libwebpdemux2 libwebpmux3 libxerces-c-dev
> libxml2-dev pkg-config unixodbc-dev uuid-dev
> And again:
> pip install pygdal=="`gdal-config --version`.*"
> with outcome:
> After all this, "paver start" starts up correctly.
> do you think these changes are correct?
> Thanks
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200914/62ae32e7/attachment-0001.html>
More information about the geonode-users mailing list
