[GeoNode-users] Geonode SPC
Ariel Nunez ingenieroariel at gmail.com
Wed Apr 7 12:58:03 PDT 2021
Fede, try goong into the django docker container and follow the trail to
the manage.py being used, if you open a shell with it, you should be able
to inspect the final django config doong from django.conf import settings
and figure out what the path to the topmost folder in the TEMPLATES_DIR
variable is, you can then look for the files within the container on those
paths and override it via a mount
On Wed, 7 Apr 2021 at 3:44 AM Federico Gianoli <alpacagis at gmail.com> wrote:
> Dear all,
> I have a stupid question about GeoNode SPC.
> I have installed it following the guide, but now I have a new kind of home
> page that I am not able to modify. If I look on geonode/templates the
> index.html file is the old one.
> Where can I find the index file of the new theme used by SPC ?
> Thank you
> Federico
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210407/73ed58d3/attachment.html>
More information about the geonode-users mailing list
