[GeoNode-users] Features not shown in attribute table
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Apr 22 00:26:27 PDT 2021
Hello Alexandria,
I cannot recognize any specific issue from the screenshot, however it does
not look normal to see those strange javascript errors.
Most probably your mapstore-client library is not updated or is broken
somehow. Try maybe to run pip install again on the requirements and a
collectstatic command if you are not running debug mode.
About the paver start question, I always suggest to run GeoServer on a
standalone tomcat and use just paver start_django in order to run GeoNode
only.
The Jetty version of GeoServer is not reliable.
Alessio.
Il giorno mar 20 apr 2021 alle ore 16:40 Alexandria Shreffler <
aleshreffler at gmail.com> ha scritto:
> Hi Alessio,
> See below for ows filtered browser console, with a refresh:
> [image: image.png]
> Also, since you mentioned GeoServer, I attempted to login to GeoServer
> with GeoNode and got this message. Is this a related problem?
> [image: image.png]
> Am I doing something wrong when I use paver to start? When I start GeoNode
> using the debugging window, GeoServer doesn't start with it, so I tried to
> use paver to start GeoServer separately in the terminal. It's saying port
> 8080 is already in use. I'm trying to run through steps in my head to
> figure out where the port is being used, but I'm out of ideas and not sure
> if that is even the direction I need to be going.
> [image: image.png]
> This is a screen shot of port use before and after running paver
> start/stop:
> [image: image.png]
> Thank you for your help! I copied my advisor into this email as he has
> also been working with me on this issue and we are trying to figure this
> out together.
> Alex
> On Tue, Apr 20, 2021 at 3:43 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Alexandria,
>> I see many errors, but cannot recognize from this screenshot anyone
>> related to WFS or WMS-T requests.
>> Could you maybe add a filter like "ows" and try to close and open again
>> the feature editor window?
>> Basically what I'm looking for is some error coming from GeoServer.
>> Something probably related to the layer permissions (just a guess).
>> Cheers,
>> Alessio.
>> Il giorno lun 19 apr 2021 alle ore 17:21 Alexandria Shreffler <
>>> Alessio, here is a screen shot of the debug window:
>>> [image: image.png]
>>> On Mon, Apr 19, 2021 at 3:48 AM Alessio Fabiani <
>>>> Hi Alexandria,
>>>> can you open the browser debug window (F-12) and see if there is any
>>>> failing request around?
>>>> Il giorno ven 16 apr 2021 alle ore 19:35 Alexandria Shreffler <
>>>>> Hello, all!
>>>>> I was hoping I could get some ideas on why the attribute table on my
>>>>> installation of GeoNode is not showing any features. It doesn't seem to
>>>>> matter the feature type (polygon, point). Feature editing and styling
>>>>> appear not to be working correctly either.
>>>>> I installed GeoNode on an Ubuntu 18.04 virtual machine using Pycharm
>>>>> as described here:
>>>>> https://github.com/gannebamm/geonode-workshop/tree/main/00_getStarted
>>>>> [image: nofeatures.PNG]
>>>>> *Alexandria Shreffler*
>>>>> Geospatial Analyst, Venango County Regional Planning Commission
>>>>> Pursuing Master's in GIS, Pennsylvania State University
>>>>> B.S. Psychology & Environmental Studies, Allegheny College
>>>>> *Phone: (814) 758-4187 or (814) 670-0897*
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>>> *Reply from Alexandria Shreffler, Geospatial Analyst for the Venango
>>> County Planning Commission.*
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210422/a83624b2/attachment-0011.png>
More information about the geonode-users
