[GeoNode-users] Docker Geonode/Geoserver Size
irland fardani
irlan128 at gmail.com
Sun Apr 25 21:17:32 PDT 2021
Hi Rizky,
thanks for your reply
My disk size is quite free, but you are right, i have a problem with the
inode
[image: geonode2.jpeg]
i am only tiled the map about 20 million image of png, but the inode
already full.
i using linux (ubuntu). is any way to solve this problem? *beside
re-installing the os
Thanks before
On Mon, Apr 26, 2021 at 10:44 AM Rizky Maulana Nugraha <rizky at kartoza.com>
wrote:
> Hi Irland,
> I don’t see anything wrong with the command output.
> Your total docker image size is around 5.151 GB.
> I see that your local volumes have 18 GB which is normal if you store your
> files there in docker volume.
> > because my docker size is about 18 Gb, the docker usually crashes.
> What I understand from your screenshots, the 18 GB size is for docker
> volume and that is normal if persistent store is used.
> Probably you misunderstand a little bit. Docker image size is not the same
> thing as Docker volume size.
> > I want to ask, how to up size the geonode docker?
> There’s no way to resize docker image size. For the docker volume size, it
> will expand indefinitely as your filesystem/disk allows if your OS is Linux.
> If your OS is Macos then usually it is limited by the size of the qcow2
> disk image itself (docker in MacOS is not native).
> > is it any variable that i must add when i do the docker compose command?
> No there isn’t any docker-compose command to control that. AFAIK there is
> some command to limit file size, but that is for log files.
> > or it is the default/maximum size of the docker geonode/geoserver only
> 18 Gb?
> I think there is no correlations.
> Some suggestion for me to figure out the root cause:
> 1. You could try checking your disk size if it has plenty of spaces to
> store 30 GB of data
> 2. What is your environment? Native Linux? In a VPS? There might be some
> limits imposed by the underlying systems
> 3. Does your filesystem optimized to store caches? You maybe run out of
> inodes. Check using “df -i” and “df -h”
> 4. Check the logs of your GeoServer. What was the error message? Why do
> you assume it was space issue?
> Regards,
> Senior Software Engineer
> Kartoza
> On 24 Apr 2021, at 11.21, irland fardani <irlan128 at gmail.com> wrote:
> Dear All,
> I install geonode and geoserver via docker. In Geoserver GWC I create a
> tiled file, and the size is very big (about 30 Gb). because my docker size
> I want to ask, how to up size the geonode docker? is it any variable that
> i must add when i do the docker compose command?or it is the
> default/maximum size of the docker geonode/geoserver only 18 Gb?
> Thanks
> <WhatsApp Image 2021-04-23 at 3.00.41 PM.jpeg>
> Irland Fardani M.T.
> +628562257785
> +6281223261345
> Program Studi Perencanaan Wilayah Kota <http://planologi.unisba.ac.id/>
> Fakultas Teknik <http://planologi.unisba.ac.id/>
> Universitas Islam Bandung <http://planologi.unisba.ac.id/>
> Hatur Nuhun
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virus-free.
> www.avg.com
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Irland Fardani M.T.
+628562257785
+6281223261345
Hatur Nuhun
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210426/3706865f/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210426/3706865f/attachment-0001.jpeg>
More information about the geonode-users
