[GeoNode-users] Deploy Geonode 3.2 behind Proxy Server
Jose Cáceres jose.atyus at gmail.com
Mon Aug 2 16:06:02 PDT 2021
Hi everyone,
I'm having some problems trying to update Geonode to 3.2.
I've been running a Geonode site in this URL:
https://geoportalouot.unah.edu.hn/. I've managed the site for a couple of
years, and have been successfully migrating from 2.10 to 3.0 to 3.1.
However i'm having issues configuring the site in 3.2
I'm running the Docker Core version of the site. My server is on an
internal IP, behind a Proxy Server. The proxy server is the one that has
the SSL certificate, and I don't have access to this server. In the current
version of the site (and on previous versions), I have had to defined this
env variables on a overrride docker-compose file:
      - GEONODE_LB_HOST_IP=geoportalouot.unah.edu.hn
      - GEONODE_LB_PORT=443
      - SITEURL=https://geoportalouot.unah.edu.hn/
      - ALLOWED_HOSTS=['geoportalouot.unah.edu.hn', ]
      - GEOSERVER_PUBLIC_LOCATION=
https://geoportalouot.unah.edu.hn/geoserver/
      - GEOSERVER_WEB_UI_LOCATION=
And in all previous versions this envs have worked fine to have my site up
and running.
However, when I try to define this same values in 3.2, I have
ERR_TOO_MANY_REDIRECTS error:
[image: Geonode_03.png]
And I haven't been able to identify the source of the problems. I noticed
the new LetsEncrypt container but I'm not sure if this is the one that
could be causing the issue, and it seems that the instructions in here: GeoNode
Core — GeoNode 3.2.1 documentation
<https://docs.geonode.org/en/master/install/advanced/core/index.html#docker>
are
not fully updated.
So any guidance that you could provide will be much appreciated, since
there are a lot of cool features in the 3.2 that I would like to be able to
use.
Thanks,
José
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: jose.atyus at gmail.com
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Sender
notified by
Mailtrack
08/02/21,
05:04:52 PM
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210802/bf57b74c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210802/bf57b74c/attachment-0001.png>
More information about the geonode-users mailing list
