[GeoNode-users] internal server error when trying geonode 2.4.1
Julio Cesar Refosco juliorefosco at hotmail.com
Fri Oct 8 12:38:08 PDT 2021
Hi Everybody,
I have Geonode 2.4 running on Ubuntu 14.04 server, installed with apt comand.
It worked fine for a lot of time and then started to present an error like this when the site was accessed. At the begining the error was observed when trying to access some layers and then even trying to access the site itself:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at webmaster at localhost to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Apache/2.4.7 (Ubuntu) Server at monitora.furb.br Port 80
This are the tail of Apache error.log
[Fri Oct 08 14:25:00.134432 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]     return self.nodelist.render(context)
[Fri Oct 08 14:25:00.134440 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]   File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Fri Oct 08 14:25:00.134455 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]     bit = self.render_node(node, context)
[Fri Oct 08 14:25:00.134464 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]   File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Fri Oct 08 14:25:00.134476 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]     return node.render(context)
[Fri Oct 08 14:25:00.134484 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]   File "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py", line 24, in render
[Fri Oct 08 14:25:00.134497 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]     request = context["request"]
[Fri Oct 08 14:25:00.134506 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]   File "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in __getitem__
[Fri Oct 08 14:25:00.134519 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503]     raise KeyError(key)
[Fri Oct 08 14:25:00.134533 2021] [:error] [pid 2795:tid 3016903488] [remote 167.248.133.41:24503] KeyError: 'request'
Could you guys give-me some help?
Thank you in advance.
Julio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20211008/8ff6b80e/attachment.html>
More information about the geonode-users mailing list
