[GeoNode-users] GeoNode 2.10.4 Map Printing Error
Anthony Njogu
anjogu0 at gmail.com
Tue Sep 28 01:19:20 PDT 2021
When printing a map in GeoNode 2.10.4, I get the following error message
attached below; When I debug I see the following error in the console;
http://3.23.95.209/proxy/?url=http://3.23.95.209:8080/geoserver/pdf/info.json?access_token=<access
token>
GeoNode Version: GeoNode 2.10.4
python 2.7
ubuntu 18.04
Thanks,
Anthony
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210928/0762ece1/attachment.html>
TypeError: a.props.capabilities is null
t/a.getLayout
/mnt/d/work/code/python/geonode-geostore-mapstore2/geonode-mapstore-client/geonode_mapstore_client/client/MapStore2/web/client/plugins/Print.jsx
t/a.renderPrintPanel
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:84:2663
t/a.renderBody
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:84:5012
value
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:84:7939
r/</t.prototype.render
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:6:25593
_renderValidatedComponentWithoutOwnerOrContext
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:2986
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:3113
_updateRenderedComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:2417
_performComponentUpdate
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:2218
updateComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:1496
receiveComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:613
receiveComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:9:19574
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:2461
updateComponent
performUpdateIfNecessary
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:829
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:9:19756
s
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:7:18648
perform
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:12:4008
perform
perform
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:7:19807
O
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:7:19976
close
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:7:19373
closeAll
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:12:4596
perform
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:12:4091
perform
O
closeAll
perform
batchedUpdates
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:35:11790
u
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:7:18861
r
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:14:31769
enqueueSetState
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:15:900
r.prototype.setState
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:29:26476
c/</p</f.prototype.onStateChange
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:29:19761
notify
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:58:7215
s</t.prototype.notifyNestedSubs
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:58:7718
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:29:19779
notify
f
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:30:12011
e
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:14669
m/</<
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:60:2329
r/</<
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:60:2774
r/<
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:60:3429
t/i.updateMapInfoState
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:30:7529
b
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:46:350
Sc.prototype.b
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:49:211
k.pq
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:136:44
G/this.V<
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:120:990
FrameRequestCallback*k.render
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:133:46
k.um
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:130:256
b
Sc.prototype.b
Yc
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:51:468
k.set
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:51:587
k.be
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:136:229
k.Oc
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:137:70
EventListener.handleEvent*k.ym
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:131:279
b
Sc.prototype.b
Yc
k.set
k.H
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:52:39
G
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:123:46
K
https://cdnjs.cloudflare.com/ajax/libs/ol3/4.6.4/ol.js:437:522
value
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:30:11243
a</t.prototype.notifyAll
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:28:28659
close
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:6632
closeAll
perform
perform
perform
O
closeAll
perform
batchedUpdates
u
r
enqueueSetState
value/<
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:83:20101
promise callback*value
http://<my IP Address>/static/mapstore/dist/1.9f211d01dcbe80559c44.chunk.js:83:20083
performInitialMount
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:35:30823
mountComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:35:29991
mountComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:9:19180
performInitialMount
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:35:31105
mountComponent
mountComponent
mountChildren
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:55:30390
_createInitialChildren
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:55:14994
mountComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:55:13208
mountComponent
performInitialMount
mountComponent
mountComponent
performInitialMount
mountComponent
mountComponent
performInitialMount
mountComponent
mountComponent
performInitialMount
mountComponent
mountComponent
performInitialMount
mountComponent
mountComponent
performInitialMount
mountComponent
mountComponent
http://<my IP Address>/static/mapstore/dist/ms2-geonode-api.js:36:2698
More information about the geonode-users
