[GeoNode-users] Develop with docker container
Pierre HARDY pierre.hardy5 at gmail.com
Wed Mar 2 03:05:28 PST 2022
Hello,
I following the instruction stated here: URL
<https://docs.geonode.org/en/3.3.x/devel/docker/index.html#start-to-develop-with-docker>
Using vscode extension, I can start a terminal session inside the
django4geonode container.
However, when I try to run the container on port 8000 it seems that the *uwsgi
*service is already running:
[image: image.png]
I can run the server on port 8800. However I would like to run it on the
port 8000 in order to have access to it remotely (it will be then served by
NGINX).
It there a way to do start dev server on port 8000 ?
Thanks !
Pierre HARDY
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220302/0ef2f889/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220302/0ef2f889/attachment-0001.png>
More information about the geonode-users mailing list
