[GeoNode-users] Geonode running
Alessio Fabiani alessio.fabiani at geosolutionsgroup.com
Mon May 23 01:12:19 PDT 2022
I guess you are missing some variables from the .env file
Try to see if something missing accordingly to
https://github.com/GeoNode/geonode/blob/3.3.x/.env#L35
On Mon, May 23, 2022 at 10:06 AM Pierre HARDY <pierre.hardy5 at gmail.com>
wrote:
> Hello everyone,
> I am currently facing this error at running geonode 3.3.1:
> [image: image.png]
> Do you have any idea of why this happens ?
> Thank you in advance for you help,
> Pierre HARDY
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220523/d5098dec/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220523/d5098dec/attachment-0001.png>
More information about the geonode-users mailing list
