[GeoNode-users] Geonode running
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Mon May 23 02:13:41 PDT 2022
That should be probably a non-blocking error. Docker is trying to refresh
the monitoring fixtures which have been already ingested previously.
The container should start anyway.
Alessio.
On Mon, May 23, 2022 at 11:02 AM Pierre HARDY <pierre.hardy5 at gmail.com>
wrote:
> Thanks for your reply,
> I noticed that added the following lines in
> [image: image.png]
> fixes the issue...
> This seems strange to me.
> [image: image.png]
> Now I have this error that comes up:
> django4geonode | Traceback (most recent call last):
> django4geonode | File
> "/usr/local/lib/python3.8/site-packages/django/db/backends/utils.py", line
> 84, in _execute
> django4geonode | return self.cursor.execute(sql, params)
> django4geonode | psycopg2.errors.UniqueViolation: duplicate key value
> violates unique constraint "monitoring_service_name_key"
> django4geonode | DETAIL: Key (name)=(geoserver-hostgeoserver) already
> exists.
> django4geonode |
> django4geonode |
> django4geonode | The above exception was the direct cause of the
> following exception:
> django4geonode |
> django4geonode | File "/usr/local/bin/django-admin.py", line 5, in
> <module>
> django4geonode | management.execute_from_command_line()
> "/usr/local/lib/python3.8/site-packages/django/core/management/__init__.py",
> line 381, in execute_from_command_line
> django4geonode | utility.execute()
> line 375, in execute
> django4geonode |
> self.fetch_command(subcommand).run_from_argv(self.argv)
> "/usr/local/lib/python3.8/site-packages/django/core/management/base.py",
> line 323, in run_from_argv
> django4geonode | self.execute(*args, **cmd_options)
> line 364, in execute
> django4geonode | output = self.handle(*args, **options)
> "/usr/local/lib/python3.8/site-packages/modeltranslation/management/commands/loaddata.py",
> line 79, in handle
> django4geonode | return super(Command, self).handle(*fixture_labels,
> **options)
> "/usr/local/lib/python3.8/site-packages/django/core/management/commands/loaddata.py",
> line 72, in handle
> django4geonode | self.loaddata(fixture_labels)
> line 114, in loaddata
> django4geonode | self.load_label(fixture_label)
> line 181, in load_label
> django4geonode | obj.save(using=self.using)
> "/usr/local/lib/python3.8/site-packages/django/core/serializers/base.py",
> line 223, in save
> django4geonode | models.Model.save_base(self.object, using=using,
> raw=True, **kwargs)
> "/usr/local/lib/python3.8/site-packages/django/db/models/base.py", line
> 780, in save_base
> django4geonode | updated = self._save_table(
> 853, in _save_table
> django4geonode | updated = self._do_update(base_qs, using, pk_val,
> values, update_fields,
> 903, in _do_update
> django4geonode | return filtered._update(values) > 0
> "/usr/local/lib/python3.8/site-packages/django/db/models/query.py", line
> 760, in _update
> query.get_compiler(self.db).execute_sql(CURSOR)
> "/usr/local/lib/python3.8/site-packages/django/db/models/sql/compiler.py",
> line 1471, in execute_sql
> django4geonode | cursor = super().execute_sql(result_type)
> line 1142, in execute_sql
> django4geonode | cursor.execute(sql, params)
> 67, in execute
> django4geonode | return self._execute_with_wrappers(sql, params,
> many=False, executor=self._execute)
> 76, in _execute_with_wrappers
> django4geonode | return executor(sql, params, many, context)
> 84, in _execute
> "/usr/local/lib/python3.8/site-packages/django/db/utils.py", line 89, in
> __exit__
> django4geonode | raise dj_exc_value.with_traceback(traceback) from
> exc_value
> 84, in _execute
> *django4geonode | django.db.utils.IntegrityError: Problem installing
> fixture '/tmp/default_monitoring_apps_docker.json': Could not load
> monitoring.Service(pk=3): duplicate key value violates unique constraint
> "monitoring_service_name_key"django4geonode | DETAIL: Key
> (name)=(geoserver-hostgeoserver) already exists.django4geonode |
> django4geonode | ERROR installing monitoring fixture: Encountered a bad
> command exit code!*
> django4geonode |
> django4geonode | Command: 'django-admin.py loaddata
> /tmp/default_monitoring_apps_docker.json --settings=geonode.settings'
> django4geonode |
> django4geonode | Exit code: 1
> django4geonode |
> django4geonode | Stdout: already printed
> django4geonode |
> django4geonode | Stderr: n/a (PTYs have no stderr)
> django4geonode |
> django4geonode |
> django4geonode | monitoringfixture tasks done
> Le lun. 23 mai 2022 à 10:12, Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> a écrit :
>> I guess you are missing some variables from the .env file
>> Try to see if something missing accordingly to
>> https://github.com/GeoNode/geonode/blob/3.3.x/.env#L35
>> On Mon, May 23, 2022 at 10:06 AM Pierre HARDY <pierre.hardy5 at gmail.com>
>> wrote:
>>> Hello everyone,
>>> I am currently facing this error at running geonode 3.3.1:
>>> [image: image.png]
>>> Do you have any idea of why this happens ?
>>> Thank you in advance for you help,
>>> Pierre HARDY
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions Group
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 333 8128928
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> Pierre HARDY
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220523/49b451f8/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220523/49b451f8/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220523/49b451f8/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220523/49b451f8/attachment-0005.png>
More information about the geonode-users
