[GeoNode-users] Disable TLS 1.0 & 1.1
Ramesh De Silva
desilvarami at gmail.com
Fri Nov 11 03:08:07 PST 2022
Dear Fabiani,
Thank you very much for the instructions. This would really help.
Kind regards
Ramesh
On Fri, Nov 11, 2022 at 4:15 PM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> If that is a docker installation you can access the NGINX configuration by
> typing
> docker-compose exec geonode sh
> edit whatever you want ant apply the conf by typing
> nginx -s reload
> On Fri, Nov 11, 2022 at 4:51 AM Ramesh De Silva <desilvarami at gmail.com>
> wrote:
>> Dear Members,
>> I have installed GeoNode 4.X using Advance Core Docker guidelines in a
>> production server very recently (After 4.X was declared as the latest
>> stable version). Everything works perfectly. But the security team of the
>> Cloud Service Provider insists on disabling TLS 1.0 and 1.1 in the system.
>> As explained in nginx documentation there was no /etc/nginx folder
>> probably because this is a docker installation. How can I disable this?
>> Your help is much appreciated.
>> Thank you.
>> Kind regards
>> Ramesh
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221111/b89674e9/attachment-0001.htm>
More information about the geonode-users
