[GeoNode-users] Geonode Harvesters
Kabatha Patrick kpparto at gmail.com
Mon Sep 25 11:38:03 PDT 2023
Hi Alessio,
No. I don't think so.
I simply installed geonode using the basic installation procedure
<https://training.geonode.geosolutionsgroup.com/master/GN3/basic_install/index.html>.
Configured the .env_local files and nginx appropriately and now running in
production mode.
On Mon, Sep 25, 2023 at 10:28 AM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> Are you running GeoNode in ASYNC mode?
> On Sun, Sep 24, 2023 at 6:45 PM Kabatha Patrick via geonode-users <
> geonode-users at lists.osgeo.org> wrote:
>> Hi there,
>> Anyone who has successfully set-up a geonode harvester. Everything seems
>> fine here:
>> [image: image.png]
>> But I don't get the list of harvestable resources as explained in this
>> tutorial
>> <https://training.geonode.geosolutionsgroup.com/master/GN2/HARVESTERS/index.html>.
>> Is there configurations that need to be done on the remote server (i.e.
>> where resources are being harvested from).
>> Anyone who has successfully set up the harvesting session?
>> Thanks,
>> GIS Analyst
>> Geography & Ecology.
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GIS Analyst
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230925/36c23f1c/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230925/36c23f1c/attachment-0001.png>
More information about the geonode-users mailing list
