[GeoNode-users] take modifed settings.py into effect for geonode docker
Michael Schultz
Schultz.Consulting at outlook.com
Mon Aug 12 22:21:26 PDT 2024
Hi collegoues,
· How to integrate settings.py or local_settings.py modifications in GeoNode docker deployment ?
· Using GeoNode 4.02 https://github.com/GeoNode/geonode/blob/master/CHANGELOG.md with default .env file, and the deployment works smoothly. (GeoNode 4.02 is the most hustle free version to my knowledge)
· Issue arises when trying to implement changes through local_settings.py or settings.py.
· Modifications to these files aren't recognized when running docker compose
· Even deleting settings.py and/or local_settings.py doesn't affect the compose; it still completes as normal. (yes docker environment/volumes/images was cleaned and purged in between the composes)
· Seeking advice on why these files aren't being picked up during the docker-compose process and how to properly use them to modify the GeoNode instance.
Greetings,
Michael
(+49)151 469 111 36, Universität Tübingen, Geographisches Institut, Rümelinstr. 19-23, D-72070 Tübingen, Westbau 1. OG / Raum W402
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240813/700d9f1f/attachment.htm>
More information about the geonode-users
