[GeoNode-users] Problem with custom EPSG
Fernando Quadro fsquadro at gmail.com
Fri Aug 23 08:12:28 PDT 2024
Hi All,
I'm working on a project that has a "custom EPSG". I've inserted this
information from this "new" EPSG into PostGIS (spatial_ref_sys table) and
also into GeoServer (epsg.properties), and so far everything is fine.
However, when I add data directly to GeoNode with this new EPSG, it doesn't
recognize it. Can you tell me if I need to add something about this "new
EPSG" to GeoNode as well?
The Custom EPSG is (South Brazil):
PROJCS["TM-FOR",GEOGCS["GCS_SIRGAS_2000",DATUM["D_SIRGAS_2000",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",300000.0],PARAMETER["False_Northing",9500000.0],PARAMETER["Central_Meridian",-38.5],PARAMETER["Scale_Factor",0.999995],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Best regards,
Fernando Quadro
http://www.fernandoquadro.com.br
https://www.linkedin.com/in/fernandoquadro/
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240823/01ce9242/attachment.htm>
More information about the geonode-users mailing list
