[GeoNode-users] cloudflare tunnel geonode
Jan Willem van der Lichte
jwgvanderlichte at gmail.com
Mon Jan 8 07:13:57 PST 2024
Dear list,
I've got a geonode 4 in docker running on my local network, and it is
working fine.
I would like to use a cloudflare tunnel to get it online.
But somehow i can't get it to work. Has anyone tried this with succes?
If I (for example) use rstudioserver to get it tunneled to the internet it
works fine.
In this rstudio docker-compose.yml I add the networks option referring to
a created bridge network called tunnel.
In the services I refer to this, see below
version: '3'
networks:
tunnel:
external: true
services:
geocompx:
image: ghcr.io/geocompx/docker:qgis
container_name: rstudio
restart: always
environment:
- USER=rstudio
- PASSWORD=blablabla
- ROOT=TRUE
ports:
- 8786:8787
volumes:
- geocompxdata:/home/rstudio/data
networks:
- tunnel
If I do the same in the geonode docker-compose.yml, it gives errors.
and geonode fails to start.
I'm a novice at this so probably I miss something, but I haven't got a clue
at the moment
Any advice is welcome :-)
Thanks,
Met groet,
Jan Willem
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240108/67d7cb59/attachment.htm>
More information about the geonode-users
