[GeoNode-users] cloudflare tunnel geonode
Jan Willem van der Lichte jwgvanderlichte at gmail.com
Thu Jan 11 03:59:33 PST 2024
Hi Henning, list
First of all, thank for your response.
I try to describe what i have done.
I created an Ubuntu server in my home network with ip 192.168.178.69
Installed docker and geonode following these instructions
https://docs.geonode.org/en/4.1.x/install/advanced/core/index.html#install-the-docker-and-docker-compose-packages-on-a-ubuntu-host
In the .env file i replaced all localhost with 192.168.178.69
I can enter the geonode site on http://192.168.178.69
so far so good
Now I want  to expose this site to the internet.
Therefor I use cloudflare-docker
First of all I created a docker network:
docker network create -d bridge tunnel
Next I created the cloudflare docker with this docker-compose.yml file.
docker-compose.yml for cloudflare
version: '3.9'
networks:
  tunnel:
    external: true
services:
  cloudflaretunnel:
    container_name: cloudflaretunnel
    image: cloudflare/cloudflared:latest
    restart: unless-stopped
    environment:
      - TUNNEL_TOKEN=$TUNNEL_TOKEN
    command: tunnel --no-autoupdate run
    networks:
      - tunnel
The tunneltoken is an environment variable.
To test if my cloudflare tunnel works, i created an rstudio docker to
expose to the interval
The compose file I used was:
docker-compose.yml for rstudio
version: '3'
networks:
  tunnel:
    external: true
services:
  geocompx:
    image: ghcr.io/geocompx/docker:qgis
    container_name: rstudio
    restart: always
    environment:
      - USER=rstudio
      - PASSWORD=blablabla
      - ROOT=TRUE
    ports:
      - 8786:8787
    volumes:
      - geocompxdata:/home/rstudio/data
    networks:
      - tunnel
volumes:
  share:
    external: true
  geocompxdata:
    driver: local
    driver_opts:
       o: bind
       type: none
       device: /home/geonode/docker/rstudio/data
I can connect my homeserver to a publichostname now. The tunnel declaration
in the yml file is needed.
After this I tried to modify the geonode docker-compose.yml as downloaded
from their github
I added the networks at the top and in every service
version: '3.9'
networks:
  tunnel:
    external: true
# Common Django template for GeoNode and Celery services below
x-common-django:
  &default-common-django
  image: geonode/geonode:4.0
  restart: on-failure
  env_file:
    - .env
  volumes:
    # - '.:/usr/src/geonode'
    - statics:/mnt/volumes/statics
    - geoserver-data-dir:/geoserver_data/data
    - backup-restore:/backup_restore
    - data:/data
    - tmp:/tmp
  depends_on:
    db:
      condition: service_healthy
    geoserver:
  networks:
    - tunnel
services:
  # Our custom django application. It includes Geonode.
  django:
    << : *default-common-django
    build:
      context: ./
      dockerfile: Dockerfile
    container_name: django4${COMPOSE_PROJECT_NAME}
    healthcheck:
      test: "curl --fail --silent --write-out 'HTTP CODE : %{http_code}\n'
--output /dev/null http://127.0.0.1:8001/"
      start_period: 60s
      interval: 60s
      timeout: 10s
      retries: 10
    environment:
      - IS_CELERY=False
    entrypoint: ["/usr/src/geonode/entrypoint.sh"]
    command: "uwsgi --ini /usr/src/geonode/uwsgi.ini"
    networks:
      - tunnel
  # Celery worker that executes celery tasks created by Django.
  celery:
    container_name: celery4${COMPOSE_PROJECT_NAME}
    depends_on:
      - django
    environment:
      - IS_CELERY=True
    command: "celery-cmd"
    networks:
      - tunnel
  # Nginx is serving django static and media files and proxies to django
and geonode
  geonode:
    image: geonode/nginx:4.0
    build: ./scripts/docker/nginx/
    container_name: nginx4${COMPOSE_PROJECT_NAME}
    environment:
      - HTTPS_HOST=${HTTPS_HOST}
      - HTTP_HOST=${HTTP_HOST}
      - HTTPS_PORT=${HTTPS_PORT}
      - HTTP_PORT=${HTTP_PORT}
      - LETSENCRYPT_MODE=${LETSENCRYPT_MODE}
      - RESOLVER=127.0.0.11
    ports:
      - "${HTTP_PORT}:80"
      - "${HTTPS_PORT}:443"
    volumes:
      - nginx-confd:/etc/nginx
      - nginx-certificates:/geonode-certificates
    restart: on-failure
    networks:
      - tunnel
  # Gets and installs letsencrypt certificates
  letsencrypt:
    image: geonode/letsencrypt:4.0
    build: ./scripts/docker/letsencrypt/
    container_name: letsencrypt4${COMPOSE_PROJECT_NAME}
    environment:
      - ADMIN_EMAIL=${ADMIN_EMAIL}
    volumes:
    restart: on-failure
    networks:
      - tunnel
  # Geoserver backend
  geoserver:
    image: geonode/geoserver:2.23.0
    container_name: geoserver4${COMPOSE_PROJECT_NAME}
    healthcheck:
--output /dev/null http://127.0.0.1:8080/geoserver/ows"
      start_period: 60s
      interval: 60s
      timeout: 10s
      retries: 10
    env_file:
      - .env
    volumes:
      - data:/data
      - tmp:/tmp
    restart: on-failure
    depends_on:
      db:
      data-dir-conf:
    networks:
      - tunnel
  data-dir-conf:
    image: geonode/geoserver_data:2.23.0
    container_name: gsconf4${COMPOSE_PROJECT_NAME}
    entrypoint: sleep infinity
    volumes:
    restart: on-failure
    healthcheck:
      test: "ls -A '/geoserver_data/data' | wc -l"
    networks:
      - tunnel
  # PostGIS database.
  db:
    # use geonode official postgis 13 image
    image: geonode/postgis:13
    command: postgres -c "max_connections=${POSTGRESQL_MAX_CONNECTIONS}"
    container_name: db4${COMPOSE_PROJECT_NAME}
    env_file:
      - .env
    volumes:
      - dbdata:/var/lib/postgresql/data
      - dbbackups:/pg_backups
    restart: on-failure
    healthcheck:
      test: "pg_isready -d postgres -U postgres"
    networks:
      - tunnel
    # uncomment to enable remote connections to postgres
    #ports:
    #  - "5432:5432"
  # Vanilla RabbitMQ service. This is needed by celery
  rabbitmq:
    image: rabbitmq:3.7-alpine
    container_name: rabbitmq4${COMPOSE_PROJECT_NAME}
    volumes:
      - rabbitmq:/var/lib/rabbitmq
    restart: on-failure
    networks:
      - tunnel
volumes:
  statics:
  nginx-confd:
  nginx-certificates:
  geoserver-data-dir:
  dbdata:
  dbbackups:
  backup-restore:
  data:
  tmp:
  rabbitmq:
After this all conainers are connected with the tunnel network, but i get a
502 bad request
When i connect all containers also to the geonode_default network, there
are no changes: 502 bad request.
I hope this clarifies the problem a bit.
Thanks
Jan Willem
Op di 9 jan 2024 om 09:45 schreef Henning Bredel via geonode-users <
geonode-users at lists.osgeo.org>:
> Hey,
> I cannot give any advice on cloudflare, but it would be good to see the
> actual error you get and the whole docker-compose file you came up with
> after changing the network.
> Best
>    Henning
> On 08.01.24 16:13, Jan Willem van der Lichte via geonode-users wrote:
> > Dear list,
> > I've got a geonode 4  in docker running on my local network, and it  is
> > working fine.
> > I would like to use a cloudflare tunnel to get it online.
> > But somehow i can't get it to work. Has anyone tried this with succes?
> > If I (for example) use rstudioserver to get it tunneled to the internet
> > it works fine.
> > In this rstudio docker-compose.yml I add the networks option  referring
> > to a created bridge network called tunnel.
> > In the services I refer to this,  see below
> > version: '3'
> > networks:
> >    tunnel:
> >      external: true
> > services:
> >    geocompx:
> > <http://ghcr.io/geocompx/docker:qgis>
> >      restart: always
> >      environment:
> >        - USER=rstudio
> >        - ROOT=TRUE
> >      ports:
> >        - 8786:8787
> >      volumes:
> >      networks:
> >        - tunnel
> > If I do the same in the geonode docker-compose.yml, it gives errors.
> > and geonode fails to start.
> > I'm a novice at this so probably I miss something, but I haven't got a
> > clue at the moment
> > Any advice is welcome  :-)
> > Thanks,
> > Met groet,
> > Jan Willem
> > geonode-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Henning Bredel
> 52°North Spatial Information Research GmbH
> Martin-Luther-King-Weg 24
> 48155 Münster, Germany
> E-Mail: h.bredel at 52north.org
> http://52north.org/
> Twitter: @FiveTwoN
> Managing Directors:
> Dr. Benedikt Gräler, Dr. Simon Jirka, Matthes Rieke
> Local Court Muenster HRB 10849
Met groet,
Jan Willem
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240111/be8db602/attachment.htm>
More information about the geonode-users mailing list
