[GeoNode-users] Geonode notification
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Tue Oct 15 00:50:41 PDT 2024
Hi Sofiane,
data editing doesn't fall under the activity tracked by GeoNode, since it's
performed directly on Geoserver through WFS-T
<https://docs.geoserver.org/main/en/user/services/wfs/reference.html#transaction>
services.
The only solution I see is either monitoring Geoserver logs, maybe
with a custom
configuration
<https://docs.geoserver.org/latest/en/user/configuration/logging.html>, or
implementing DB triggers
<https://www.postgresql.org/docs/current/sql-createtrigger.html>.
Giovanni
On Tue, Oct 15, 2024 at 9:37 AM Sofiane Kouidri via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hello
> I have deployed GeoNode in our company’s data center, and we now have
> around 300 users and two administrators. In the recent activity log, I can
> only see the actions of these two administrators, such as downloading or
> deleting maps or datasets. However, even when other users or the
> administrators update a map (e.g., adding points or lines and filling out
> attribute tables), this does not show up in the recent activity. Last week,
> one user made a significant update, but I wasn’t able to identify who it
> was. Is there a solution for this issue?
> Cordialement.
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20241015/9d86c7aa/attachment.htm>
More information about the geonode-users
