[GeoNode-users] Failed Upload Dataset
Abdul Hamid
ahamidplg at gmail.com
Mon Sep 23 22:33:51 PDT 2024
Hi Giovanni
Sorry for late respon your answer,
Here log taken from access.log on nginx internal proxy :
10.10.1.225 - - [24/Sep/2024:12:29:06 +0700] "GET
/api/v2/executionrequest?filter%7Baction%7D=import&filter%7Bsource%7D=upload&page=1&page_size=99999
HTTP/1.1" 200 38236 "https://geoportal.lahatkab.go.id/catalogue/"
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML,
like Gecko) Chrome/129.0.0.0 Safari/537.36"
10.10.1.225 - - [24/Sep/2024:12:29:16 +0700] "GET
like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0"
10.10.1.225 - - [24/Sep/2024:12:29:18 +0700] "POST
/proxy/?url=http%3A%2F%2Fgeoportal.lahatkab.go.id%2Fapi%2Fv2%2Fuploads%2Fupload
HTTP/1.1" 500 180699 "https://geoportal.lahatkab.go.id/catalogue/"
10.10.1.1 - - [24/Sep/2024:12:29:19 +0700] "HEAD / HTTP/1.0" 200 0 "-" "-"
10.10.1.225 - - [24/Sep/2024:12:29:19 +0700] "GET
10.10.1.225 - - [24/Sep/2024:12:29:22 +0700] "GET
10.10.1.225 - - [24/Sep/2024:12:29:26 +0700] "GET
10.10.1.225 - - [24/Sep/2024:12:29:29 +0700] "GET
10.10.1.225 - - [24/Sep/2024:12:29:32 +0700] "GET
10.10.1.225 - - [24/Sep/2024:12:29:35 +0700] "GET
this log taken when I uploaded the dataset like : .shp file, after
submited error warning appear. as information this geonode on behind nat
( geononde server ip 10.10.1.222 and ip 10.10.1.255 reverse proxy
(external proxy)
Br
Hamid
Pada 27/08/2024 15:48, Giovanni Allegri menulis:
> Take a look at the network requests performed during the upload. You
> will probably see a few requests against the /proxy URL.
> If you report here those requests I might help you figuring out the
> misconfiguration.
> Giovanni
> On Mon, Aug 26, 2024 at 3:37 PM Abdul Hamid <ahamidplg at gmail.com> wrote:
> I'am running on ubuntu 22.04 via nginx its not running on docker,
> site url using hostname, this is configuration : geonode with
> nginx ---> reverse proxy (public ip), on SITEURL it's hostname self.
> Br
> Hamid
> Pada 26/08/2024 17:24, Giovanni Allegri menulis:
>> From logs, I suspect the upload is routed to the internal GeoNode
>> proxy, which is unexpected.
>> I think you have something wrong with your configs. Double-check
>> the settings related to SITEURL.
>> Is it a Docker?
>> Giovanni
>> On Mon, Aug 26, 2024 at 9:23 AM Abdul Hamid via geonode-users
>> <geonode-users at lists.osgeo.org> wrote:
>> Hi all
>> I tried to upload ESRI data into geonode (using geonode
>> 4.2.5) but after selecting the file and clicking upload there
>> was a failure, as shown in the image below
>> Geonode
>> this is log taken from /var/log/geonode.log
>> Internal Server Error: /proxy/
>> Traceback (most recent call last):
>> File
>> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/core/handlers/exception.py",
>> line 47, in inner
>> response = get_response(request)
>> File
>> "/home/adminkominfo/.virtualenvs/geonode/lib/python3.10/site-packages/django/core/handlers/base.py",
>> line 181, in _get_response
>> response = wrapped_callback(request, *callback_args,
>> **callback_kwargs)
>> File
>> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/utils/decorators.py",
>> line 130, in _wrapped_view
>> response = view_func(request, *args, **kwargs)
>> File "/opt/geonode/./geonode/proxy/views.py", line 185, in
>> proxy
>> _data = request.body.decode("utf-8")
>> File
>> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/http/request.py",
>> line 330, in body
>> raise RawPostDataException("You cannot access body after
>> reading from request's data stream")
>> django.http.request.RawPostDataException: You cannot access
>> body after reading from request's data stream
>> Thank You
>> Br
>> Hamid
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us
>> <http://bit.ly/gs-services-us>for more information.==Dott.
>> Giovanni Allegri
>> Technical Lead / Project Manager
>> GeoSolutions Groupphone: +39 0584 962313cell: +39 345 2815774
>> fax: +39 0584 1660272 https://www.geosolutionsgroup.com/
>> <https://www.geosolutionsgroup.com/>http://twitter.com/geosolutions_it
>> <http://twitter.com/geosolutions_it>-------------------------------------------------------
>> Con riferimento alla normativa sul trattamento dei dati personali
>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>> dati “GDPR”), si precisa che ogni circostanza inerente alla
>> presente email (il suo contenuto, gli eventuali allegati, etc.) è
>> un dato la cui conoscenza è riservata al/i solo/i destinatario/i
>> indicati dallo scrivente. Se il messaggio Le è giunto per errore,
>> è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
>> sarei comunque grato se potesse darmene notizia.This email is
>> intended only for the person or entity to which it is addressed
>> and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided
>> by European Regulation 2016/679 “GDPR” - copying, dissemination
>> or use of this e-mail or the information herein by anyone other
>> than the intended recipient is prohibited. If you have received
>> this email by mistake, please notify us immediately by telephone
>> or e-mail.
> Visit http://bit.ly/gs-services-us <http://bit.ly/gs-services-us>for
> more information.==Dott. Giovanni Allegri
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
> “GDPR”), si precisa che ogni circostanza inerente alla presente email
> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
> conoscenza è riservata al/i solo/i destinatario/i indicati dallo
> scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
> cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
> se potesse darmene notizia.This email is intended only for the person
> or entity to which it is addressed and may contain information that is
> privileged, confidential or otherwise protected from disclosure. We
> remind that - as provided by European Regulation 2016/679 “GDPR” -
> copying, dissemination or use of this e-mail or the information herein
> by anyone other than the intended recipient is prohibited. If you have
> received this email by mistake, please notify us immediately by
> telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240924/59d49352/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240924/59d49352/attachment-0001.png>
More information about the geonode-users
