[GeoNode-users] Postgres Passwords
Édson Flávio de Souza
edson.flavio at gmail.com
Thu Aug 7 14:45:20 PDT 2025
Édson Flávio reagiu pelo Gmail
<https://www.google.com/gmail/about/?utm_source=gmail-in-product&utm_medium=et&utm_campaign=emojireactionemail#app>
Em qui., 31 de jul. de 2025 04:30, Kabatha Patrick <kpparto at gmail.com>
escreveu:
> Thanks Edson,
> It worked. Thanks for your response.
> Cheers!
> On Tue, Jul 29, 2025 at 11:21 PM Édson Flávio de Souza <
> edson.flavio at gmail.com> wrote:
>> Hi, adjust the variables in settings.py to reflect your changes.
>> Edson Flavio
>> 41-98872-5118
>> @ef_souza - Twitter e Instagram
>> Em ter., 22 de jul. de 2025 15:38, Kabatha Patrick via geonode-users <
>> geonode-users at lists.osgeo.org> escreveu:
>>> Hi,
>>> I've changed my default postgres password for the 2 roles (postgres and
>>> geonode) and adjusted accordingly the .env file and geoserver stores. But
>>> for some reason, I still get this error message when I try to align the DB
>>> and GeoNode:
>>> ./paver_prod.sh sync
>>> ---> pavement.sync
>>> python -W ignore manage.py makemigrations --noinput
>>> Traceback (most recent call last):
>>> File "/opt/geonode-project/my_geonode/src/manage.py", line 31, in
>>> <module>
>>> execute_from_command_line(sys.argv)
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/__init__.py",
>>> line 419, in execute_from_command_line
>>> utility.execute()
>>> File
>>> line 413, in execute
>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/base.py",
>>> line 354, in run_from_argv
>>> self.execute(*args, **cmd_options)
>>> File
>>> line 398, in execute
>>> output = self.handle(*args, **options)
>>> File
>>> line 89, in wrapped
>>> res = handle_func(*args, **kwargs)
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/commands/makemigrations.py",
>>> line 103, in handle
>>> loader.check_consistent_history(connection)
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/migrations/loader.py",
>>> line 294, in check_consistent_history
>>> applied = recorder.applied_migrations()
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/migrations/recorder.py",
>>> line 77, in applied_migrations
>>> if self.has_table():
>>> File
>>> line 55, in has_table
>>> with self.connection.cursor() as cursor:
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/utils/asyncio.py",
>>> line 33, in inner
>>> return func(*args, **kwargs)
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/backends/base/base.py",
>>> line 259, in cursor
>>> return self._cursor()
>>> File
>>> line 235, in _cursor
>>> self.ensure_connection()
>>> File
>>> line 33, in inner
>>> File
>>> line 219, in ensure_connection
>>> self.connect()
>>> File
>>> line 33, in inner
>>> File
>>> line 199, in connect
>>> conn_params = self.get_connection_params()
>>> File
>>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/backends/postgresql/base.py",
>>> line 157, in get_connection_params
>>> raise ImproperlyConfigured(
>>> django.core.exceptions.ImproperlyConfigured: settings.DATABASES is
>>> improperly configured. Please supply the NAME value.
>>> Captured Task Output:
>>> ---> pavement.sync
>>> Build failed running pavement.sync: Subprocess return code: 1
>>> Anyone else who has had the same challenges?
>>> /Pat.
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
Name: not available
Type: text/vnd.google.email-reaction+json
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250807/5523ddd6/attachment.bin>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250807/5523ddd6/attachment.htm>
More information about the geonode-users
