[GeoNode-users] Postgres Passwords
    Kabatha Patrick
    kpparto at gmail.com
    Tue Jul 22 11:38:40 PDT 2025
I've changed my default postgres password for the 2 roles (postgres and
geonode) and adjusted accordingly the .env file and geoserver stores. But
for some reason, I still get this error message when I try to align the DB
and GeoNode:
./paver_prod.sh sync
---> pavement.sync
 python -W ignore manage.py makemigrations --noinput
  File "/opt/geonode-project/my_geonode/src/manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/__init__.py",
line 419, in execute_from_command_line
    utility.execute()
  File
line 413, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/base.py",
line 354, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 398, in execute
    output = self.handle(*args, **options)
  File
line 89, in wrapped
    res = handle_func(*args, **kwargs)
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/commands/makemigrations.py",
line 103, in handle
    loader.check_consistent_history(connection)
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/migrations/loader.py",
line 294, in check_consistent_history
    applied = recorder.applied_migrations()
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/migrations/recorder.py",
line 77, in applied_migrations
    if self.has_table():
  File
line 55, in has_table
    with self.connection.cursor() as cursor:
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/utils/asyncio.py",
line 33, in inner
    return func(*args, **kwargs)
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/backends/base/base.py",
line 259, in cursor
    return self._cursor()
  File
line 235, in _cursor
    self.ensure_connection()
  File
line 33, in inner
  File
line 219, in ensure_connection
    self.connect()
  File
line 33, in inner
  File
line 199, in connect
    conn_params = self.get_connection_params()
  File
"/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/backends/postgresql/base.py",
line 157, in get_connection_params
    raise ImproperlyConfigured(
django.core.exceptions.ImproperlyConfigured: settings.DATABASES is
improperly configured. Please supply the NAME value.
Captured Task Output:
---> pavement.sync
Build failed running pavement.sync: Subprocess return code: 1
Anyone else who has had the same challenges?
/Pat.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250722/bfb69c23/attachment.htm>
More information about the geonode-users
