[GeoNode-users] Postgres Passwords
    Kabatha Patrick
    kpparto at gmail.com
    Thu Jul 31 00:30:12 PDT 2025
Thanks Edson,
It worked. Thanks for your response.
Cheers!
On Tue, Jul 29, 2025 at 11:21 PM Édson Flávio de Souza <
edson.flavio at gmail.com> wrote:
> Hi, adjust the variables in settings.py to reflect your changes.
> Edson Flavio
> 41-98872-5118
> @ef_souza - Twitter e Instagram
> Em ter., 22 de jul. de 2025 15:38, Kabatha Patrick via geonode-users <
> geonode-users at lists.osgeo.org> escreveu:
>> Hi,
>> I've changed my default postgres password for the 2 roles (postgres and
>> geonode) and adjusted accordingly the .env file and geoserver stores. But
>> for some reason, I still get this error message when I try to align the DB
>> and GeoNode:
>> ./paver_prod.sh sync
>> ---> pavement.sync
>>  python -W ignore manage.py makemigrations --noinput
>> Traceback (most recent call last):
>>   File "/opt/geonode-project/my_geonode/src/manage.py", line 31, in
>> <module>
>>     execute_from_command_line(sys.argv)
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/__init__.py",
>> line 419, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 413, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/base.py",
>> line 354, in run_from_argv
>>     self.execute(*args, **cmd_options)
>>   File
>> line 398, in execute
>>     output = self.handle(*args, **options)
>>   File
>> line 89, in wrapped
>>     res = handle_func(*args, **kwargs)
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/core/management/commands/makemigrations.py",
>> line 103, in handle
>>     loader.check_consistent_history(connection)
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/migrations/loader.py",
>> line 294, in check_consistent_history
>>     applied = recorder.applied_migrations()
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/migrations/recorder.py",
>> line 77, in applied_migrations
>>     if self.has_table():
>>   File
>> line 55, in has_table
>>     with self.connection.cursor() as cursor:
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/utils/asyncio.py",
>> line 33, in inner
>>     return func(*args, **kwargs)
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/backends/base/base.py",
>> line 259, in cursor
>>     return self._cursor()
>>   File
>> line 235, in _cursor
>>     self.ensure_connection()
>>   File
>> line 33, in inner
>>   File
>> line 219, in ensure_connection
>>     self.connect()
>>   File
>> line 33, in inner
>>   File
>> line 199, in connect
>>     conn_params = self.get_connection_params()
>>   File
>> "/home/jpkadmin/.virtualenvs/my_geonode/lib/python3.10/site-packages/django/db/backends/postgresql/base.py",
>> line 157, in get_connection_params
>>     raise ImproperlyConfigured(
>> django.core.exceptions.ImproperlyConfigured: settings.DATABASES is
>> improperly configured. Please supply the NAME value.
>> Captured Task Output:
>> ---> pavement.sync
>> Build failed running pavement.sync: Subprocess return code: 1
>> Anyone else who has had the same challenges?
>> /Pat.
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250731/92a87399/attachment.htm>
More information about the geonode-users
