[GeoNode-users] Upgrading 4.1.x to 4.4.3- layers not available
Segura, German German.Segura at icf.com
Tue Jun 3 07:58:16 PDT 2025
I am upgrading from 4.1.x to 4.4.3, I setup my test environment with same configuration as my current production environment including the  databases and the data, after compiling and running the docker instances I can access the new instance, I can see all the datasets but I cannot download any of them, so I accessed Geoserver Admin and I found that there is not a Store neither Layers, so I recreated the store and I noticed that I need to go over each layer and publish it, then add all the Metadata Links.
Is there any other way to do that? I have more than 60 layers each one with 8+ metadata links.
My architecture:
  *   EC2 Instance Ubuntu 22.04 LTS
  *   Geonode project running docker instances
     *   GEONODE_BASE_IMAGE_VERSION=latest
     *   NGINX_BASE_IMAGE_VERSION=latest
     *   LETSENCRYPT_BASE_IMAGE_VERSION=latest
     *   GEOSERVER_BASE_IMAGE_VERSION=2.24.4-latest
     *   GEOSERVER_DATA_BASE_IMAGE_VERSION=latest
     *   POSTGRES_BASE_IMAGE_VERSION=latest
  *   DB AWS RDS Postgres:
     *   geonode44_stage
     *   geonode44_stage_data
[A picture containing object, clock  Description automatically generated]
GERMAN  SEGURA, Sr Java Developer
icf.com  |  LinkedIn<https://www.linkedin.com/company/icf-international>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250603/df022d1e/attachment.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250603/df022d1e/attachment.jpg>
More information about the geonode-users mailing list
