[GeoNode-users] filter charts dashboard
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Tue Nov 18 04:31:43 PST 2025
Hi Mariano,
You can follow the documentation for Mapstore here
<https://docs.mapstore.geosolutionsgroup.com/en/latest/user-guide/connecting-widgets/>,
where the connections between widgets is explained.
Mapstore is the framework on which the GeoNode client is built.
Best,
Giovanni
On Mon, Nov 17, 2025 at 9:07 PM Mariano Miguel Merlo via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hello
> I need to apply dynamic filters on tables or charts like this image. Do I
> need to configure anything? Is possible in Geonode 4.4.3?
> Thanks.
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20251118/99c9035b/attachment.htm>
More information about the geonode-users
