[GeoNode-users] Is there a way to add Vector tiles layers and XYZ tile layers in Geonode/Mapstore2?
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Wed Aug 19 03:28:35 PDT 2026
Ciao Amedeo,
At the moment, MS doesn't support vector tiles. Several PoCs (including
support for Cesium) and analyses have been done, even recently, but without
a roadmap at the moment.
Giovanni
On Sat, Aug 15, 2026 at 12:56 AM Amedeo Fadini via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi everybody,
> it seems that the list hasn't much post: indeed the software works very
> well, installation is straightforward, documentation is awesome and users
> don'thave so much problem to solve.
> At INFO/RAC we need to transfer all the information that is published here:
> https://app.mapx.org/?project=MX-ON9-MA9-O1D-KKO-BER&language=en&theme=color_light
> To the knowledge magement platform based on Geonode
> https://kmap.info-rac.org/catalogue/#/map/22889
> WMS services are working but it seems that some layers area only available
> as a mapbx vector vector tiles with a url like this:
> https://api.mapx.org/get/tile/{x}/{y}/{z}.mvt?idView=MX-PIVBG-4WGBM-ZTMNP
> Is there any possibility to have this layers in the same geonode map?
> Thamk-you
> Amefad
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20260819/4f1fb77d/attachment-0001.htm>
More information about the geonode-users
