[Geoprisma-dev] GeoPrisma General doc structure, proposition
Yves Moisan yves.moisan at boreal-is.com
Wed Dec 2 12:15:50 EST 2009
> One big missing portion of the
> "installation" tutorial is how to create new "locale" files.  I've never
> used them yet, so I would like to see a simple "how to" added to the doc.
Did you mean add a new locale driver or add a new locale file ?  If the
former,  I've done a first pass : r734.  Some of the code blocks may not
be accurate, but it should be close.  If the latter, then it would take
a how to make .po files (and related po template).  Is that what you
meant ?
Yves
More information about the Geoprisma-dev mailing list
