[Geoprisma-dev] GeoPrisma General doc structure, proposition
Alexandre Dube adube at mapgears.com
Wed Dec 2 12:52:47 EST 2009
Yves Moisan wrote:
> Did you mean add a new locale driver or add a new locale file ?  If the
> former,  I've done a first pass : r734.  Some of the code blocks may not
> be accurate, but it should be close.  If the latter, then it would take
> a how to make .po files (and related po template).  Is that what you
> meant ?
> Yves
Yeah, I meant a "how to make and use new .po files".
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
