[Geoprisma-dev] Apache gotcha for windows
Yves Moisan yves.moisan at boreal-is.com
Fri Dec 4 11:14:32 EST 2009
Hi List,
I had a problem running CGI scripts (tilecache and featureserver) on
geoprisma.org with "Premature end of scripts" errors.  Turns out I was
(probably) bypassing all settings with this line :
ScriptInterpreterSource registry
which says "use the windows registry to find where Python (and other
scripts) is".
I had found the info about using that directive here:
http://www.imladris.com/Scripts/PythonForWindows.html, but unfortunately
it looks like it's a bit tricky to use.  Just in case someone else gets
bitten in the arse.  Or someone finds a way to use the directive
appropriately.
Yves
More information about the Geoprisma-dev mailing list
