[Geoprisma-dev] Layer loading problem
Yves Moisan
yves.moisan at boreal-is.com
Fri Dec 4 13:47:40 EST 2009
Hi All,
This is an Openlayers question. I'm customizing the initialview to
highlight the zoomed to feature(s) and I find that in some cases the
layer is not fully loaded before the select is done. In the code below,
things work if I leave the alert (the layer is given time to load) but
if I take it out the case with 1 feature works but not when there are
many :
var oFormat = new OpenLayers.Format.GeoJSON();
var oFeatures = oFormat.read(response.responseText);
var layers = objGPWidget]]><xsl:value-of select="$pMapName" /><![CDATA[.getLayersByResource("]]><xsl:value-of select="$resourceName" /><![CDATA[","featureserver");
// Next line used to check if there is a featureserver layer; for initialview, this is required so no need to alert
// (!layers[0]) ? alert("no FS layer"): alert("FS layer = " + layers[0].name);
]]><xsl:if test="./options/highlight = 'true'"><![CDATA[
// alert("Highlight on")
function selectFeature(layer, fid)
for(var i = 0; i<layer.features.length;++i)
if (layer.features[i].fid == fid)
FeatureSelectControl.select(layer.features[i]);
alert("Highlight on");
break;
FeatureSelectControl = new OpenLayers.Control.SelectFeature( layers[0], {});
objGPWidget]]><xsl:value-of select="$pMapName" /><![CDATA[.addControl(FeatureSelectControl);
]]></xsl:if><![CDATA[
if(oFeatures && oFeatures.length > 0)
{ // THIS CASE WORKS
var bounds = oFeatures[0].geometry.getBounds();
selectFeature(layers[0],oFeatures[0].fid);
for(var i = 1; i<oFeatures.length;++i)
{ // THIS CASE DOES NOT WORK
bounds.extend(oFeatures[i].geometry.getBounds());
selectFeature(layers[0],oFeatures[i].fid);
How can I wait for the layer to display before selecting ?
TIA,
Yves
More information about the Geoprisma-dev
