[Geoprisma-dev] Initial page load generate multiple WMS request,
one with bad params
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Dec 7 17:51:54 EST 2009
I was checking the apache logs while running the above url and on inital
load of the page I am getting three WMS requests.
http://imaptools.com:8080/project/myproj2/
1) has a bogus image size (WIDTH=5000&HEIGHT=775) and fails because it
exceeds the default image max size which I think it 2000 in mapserver.
But if it succeeded this would be bad from a performance point of view
and tie up a lot of memory and resource computing the image.
http://imaptools.com:8080/project/myproj2/proxy.php?osmservice=S_WMS_IMT_MS&osmtoken=TODO%20Delete%20this&osmresource[]=R_ONEMILEETJ&osmresource[]=R_LAKES&osmresource[]=R_PARCELS&osmresource[]=R_RAILROAD&osmresource[]=R_FMROADS&osmresource[]=R_SERVICEROADS&osmresource[]=R_STREETS&osmresource[]=R_HIGHWAYS&osmresource[]=R_INTERSTATE&osmresource[]=R_VOTINGPRECINCTS&osmresource[]=R_ZONING&FORMAT=image%2Fpng&TRANSPARENT=false&LAYERS=onemileetj,lakes,parcels,railroad,fmroads,serviceroads,streets,highways,interstate,votingprecincts,zoning&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-195678792.375,-30330212.818125,195678792.375,30330212.818125&WIDTH=5000&HEIGHT=775
2) the next request appears to be at the maximum extents extents of the
world but not those defined in the map widget extents, but with the
correct viewport what I'm guessing is the correct viewport size of
610x610 although I'm not sure how it cam up with that number unless by
some random chance that the browser geometry just happened to make it
square.
http://imaptools.com:8080/project/myproj2/proxy.php?osmservice=S_WMS_IMT_MS&osmtoken=TODO%20Delete%20this&osmresource[]=R_ONEMILEETJ&osmresource[]=R_LAKES&osmresource[]=R_PARCELS&osmresource[]=R_RAILROAD&osmresource[]=R_FMROADS&osmresource[]=R_SERVICEROADS&osmresource[]=R_STREETS&osmresource[]=R_HIGHWAYS&osmresource[]=R_INTERSTATE&osmresource[]=R_VOTINGPRECINCTS&osmresource[]=R_ZONING&FORMAT=image%2Fpng&TRANSPARENT=false&LAYERS=onemileetj,lakes,parcels,railroad,fmroads,serviceroads,streets,highways,interstate,votingprecincts,zoning&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-23872812.66975,-23872812.66975,23872812.66975,23872812.66975&WIDTH=610&HEIGHT=610
3) the final image you see after the browser is done loading. This third
request might be because I added a map.setcenter() call to the template.
http://imaptools.com:8080/project/myproj2/proxy.php?osmservice=S_WMS_IMT_MS&osmtoken=TODO%20Delete%20this&osmresource[]=R_ONEMILEETJ&osmresource[]=R_LAKES&osmresource[]=R_PARCELS&osmresource[]=R_RAILROAD&osmresource[]=R_FMROADS&osmresource[]=R_SERVICEROADS&osmresource[]=R_STREETS&osmresource[]=R_HIGHWAYS&osmresource[]=R_INTERSTATE&osmresource[]=R_VOTINGPRECINCTS&osmresource[]=R_ZONING&FORMAT=image%2Fpng&TRANSPARENT=false&LAYERS=onemileetj,lakes,parcels,railroad,fmroads,serviceroads,streets,highways,interstate,votingprecincts,zoning&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-10750132.512901,3763907.2951822,-10726819.219279,3787220.588805&WIDTH=610&HEIGHT=610
If this sounds like a bug, let me know and I will write a ticket for it.
Thanks,
-Steve
More information about the Geoprisma-dev
