[Geoprisma-dev] Caching for the Proxy
Alexandre Dube
adube at mapgears.com
Tue Dec 15 13:00:31 EST 2009
Yves Moisan wrote:
> Do you happen to know of software that would allow me to view all the
> diffs in a patch on a side by side display ?
No, I usually apply the patch and check what's changed with an svn diff
on the file I'm interested in.
> Response headers *without* TC caching --
> org_geoprisma_SettingImpl::setTileCacheProxyCaching(false); :
Sorry, maybe my explanation wasn't clear enough : you don't need so set
both setProxyCaching and setTileCacheProxyCaching, just pick one
(comment the other). Was it the problem ?
> However, no matter how I set the three set*Caching directives in
> common.php, at one point tiles get cached in the browser. It does not
> seem possible to have AJAX requests for images on every zoom in/out
> action, which is what I would expect if all flags were set to false.
On which browser ? I made some tests on IE and FF and both send
requests when the cache is turned off. You can check your apache
access.log to validate that.
> Also, did you have anything special to do with your TileCache. IIRC at
> one point you raised an issue ??
No. The caching used by tilecache (mod_expires or mod_xsendfile) are
ignored with this method
> I'll be coming back with a few patches of my own soon and also on the
> workspace issue. And oh yes : I haven't reviewed your code : just how
> it works.
Thanks a lot.
Alexandre
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
