[Geoprisma-dev] XMLMapContextConfig prototype driver
Alexandre Dube
adube at mapgears.com
Thu Dec 24 11:01:36 EST 2009
Hi Steve,
If I understand your question well, you want to know if a vector layer
object would be automatically created (and added to the map) if you only
have a 'featureserver' datastore in the Resource ?
I would say : if it doesn't have a widget that use it then 'no', else
'yes' (that fits the current default behavior).
The issue here is that the resource wouldn't be added to the map at
all and I guess that you would want to have at least a layer to be added
to the map even if it would be a 'vector' one with no widget that would
interact with it, is that so ? If so, I guess it would be okay to add
it to the map too anyway as a default behavior.
So it's a choice. Since it's only a 'default' behavior, either are
fine by me. What do you think ?
Kind regards and ho ho hope it helps,
Alexandre
Stephen Woodbridge wrote:
> Alexandre,
> Wow, you have put a lot of work and thought into this proposal. Looks
> really great.
> I have one question about your [1] note. If I have a vector only layer
> in featureserver and no wms services for it, will it get configured or
> would/could I need to take explicit action to have it configured
> appropriately? I guess to some extent you could just say you have to
> have a WMS service for each featureserver service, but this seems like
> an arbitrary constraint especially if I don't own the featureserver or
> proxy request off to another server.
> Just food for thought. Very nice proposal and a lot of ideas and
> information to digest.
> Merry Christmas to all,
> -Steve
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
