[Geoprisma-dev] ExtJS bug fixes now costs money
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Mon Nov 2 11:53:06 EST 2009
Yves Moisan schrieb:
>> jQuery itself is a very small library, but there is also jQuery UI [1],
>> which contains a lot of widget plugins. But still, ExtJS contains way
>> more functionality.
> Hi Christoph,
> I learned meanwhile that bug fix releases of ExtJS were only for
> subscribers and that "other" (non privileged I guess we could call them)
> users only get a release every 6 months or so.
>> However you can find jQuery plugins for almost all scenarios imaginable,
>> but it would be nice to have them bundled (and quality tested), like in
>> ExtJS.
>> Mapbender is based on jQuery (since version 2.5), and from version 2.7
>> onwards, we will use the jQuery UI library as well.
>> Licensing was a main issue why we chose jQuery over ExtJS, besides the
>> fact that jQuery only costs a few kB.
> MapBender is GPL right ?  I think this was Josh's main concern about
> ExtJS (the licensing options), but I may be wrong.
Mapbender now has a dual license [1], GPL and Simplified BSD.
Thanks everyone for the warm welcome, I'm looking forward to
collaborating :-)
Christoph
[1]
http://trac.osgeo.org/mapbender/browser/trunk/mapbender/license/license.txt?format=raw
> Vielen danke,
> Yves
>> Cheers,
>> Christoph
>> [1] http://jqueryui.com/
>>> Daniel
>> Geoprisma-dev mailing list
>> Geoprisma-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Geoprisma-dev mailing list
