[Geoprisma-dev] ExtJS bug fixes now costs money
Yves Moisan
yves.moisan at boreal-is.com
Mon Nov 2 11:09:32 EST 2009
> jQuery itself is a very small library, but there is also jQuery UI [1],
> which contains a lot of widget plugins. But still, ExtJS contains way
> more functionality.
Hi Christoph,
I learned meanwhile that bug fix releases of ExtJS were only for
subscribers and that "other" (non privileged I guess we could call them)
users only get a release every 6 months or so.
> However you can find jQuery plugins for almost all scenarios imaginable,
> but it would be nice to have them bundled (and quality tested), like in
> ExtJS.
> Mapbender is based on jQuery (since version 2.5), and from version 2.7
> onwards, we will use the jQuery UI library as well.
> Licensing was a main issue why we chose jQuery over ExtJS, besides the
> fact that jQuery only costs a few kB.
MapBender is GPL right ? I think this was Josh's main concern about
ExtJS (the licensing options), but I may be wrong.
Vielen danke,
Yves
> Cheers,
> Christoph
> [1] http://jqueryui.com/
> > Daniel
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
More information about the Geoprisma-dev
