[Geoprisma-dev] Trac
Yves Moisan
yves.moisan at boreal-is.com
Tue Nov 10 10:16:36 EST 2009
Le lundi 09 novembre 2009 à 12:02 -0500, Daniel Morissette a écrit :
> Yves Moisan wrote:
> > Or maybe you'd like
> > to sort active tickets per component type ? Trac provides default
> > filters for version and milestone. Do we need to filter by component ?
> Or could we have used keywords with the widget name instead of creating
> components for each one? I fear that one component per widget will
> result in a bloated list of components that will be a nightmare to
> maintain in the long run,
Right. I did a first go (added several widget types) but since not many
tickets are there already, I will go back and leave just the basic
components (the 6 or 7 initial ones). It's a good idea to let people
add keywords to specify issues. In fact, I had this very problem with a
bug that applied equally to 2 or 3 different widgets, so I would have
selected a component for one of those specific widgets and then added
keywords.
Does that sound good to all ?
Thanx Daniel,
Yves
More information about the Geoprisma-dev
