[Geoprisma-dev] #9250 (Add jQuery Tools to base install) – Plone
Yves Moisan yves.moisan at boreal-is.com
Wed Nov 11 15:14:05 EST 2009
> You're absolutely about that.  The website geoprisma.org doesn't really
> need something as big as ExtJS since it's just a website and not an
> "application".  Some work could be done to change the JS library of
> geoprisma.org to something lighter, such as jQuery Tools.
If you have suggestions, I'm all ears.  The current set up is a bit
tricky to move as some ExtJS components get their data from php scripts
that generate JSON dynamically so I wouldn't move quickly on that for
now.
>   But, in the end, I still think that GeoPrisma (itself) is destined to
> be more "application-like" and gain a lot fo benefits to use what's
> already existent (GeoExt / MapFish ==> ExtJS).
I agree.  Maybe we could be closer to the web, but the current stack is
definitely there to stay for a while.
Yves
More information about the Geoprisma-dev mailing list
