> Simple question : where can I build the widget doc ? I can see the > following [1] on geoprisma.org, but not locally. Go to the "Documentation" tab and you should see "Build" just below the "General" tab. Does that work ? Yves > > Thanks, > > [1] http://geoprisma.org/dist/build/html/widgets/list/Shortcut.html >
